jdm sir hood fit with k20 swap
I was just seeing if anybody have info on this.
Any thing can help me konwing what step to take before start moving towards the next step.
Re: jdm sir hood fit with k20 swap (LoveOfMoney)
It will fit with some cutting of the under webbing.........or you can buy the FiberImages SIR Style (which has no webbing underneath) and it is supposed to have around 1/4 inch clearance.
Re: (fulblown612)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fulblown612 »</TD></TR><TR><TD CLASS="quote">Thinks for all info that took a bit off my mind.</TD></TR></TABLE>
Fiberimages is your best bet cause it will require the least modification, which is pretty much nothing But you can use other SIR Style hoods and just cut the webbing to make it work
Re: jdm sir hood fit with k20 swap (fulblown612)
they speak the truth. fiberimages has no under skeleton and are the best for engine clearance.
do you have a real ef8 jdm frontend on the car?
I had ef8 SiR hoods made with them:
https://honda-tech.com/zerothread?id=1651886
And they always stock the usdm SiR STYLE which has the bump upwards if you dont have a jdm clip on the car.
RicedREX
05-19-2006 07:13 AM
RicedREX
10-28-2003 04:42 PM
