DA MC, BB and prop valve question
Ok so I put the DA rear disc on my 89 CRX a long time back, but when i run the brakes hard i get brake fade... has anyone ran them with the just the setup I had and then put on the Master cylinder, Brake Booster, and 40/40 Prop valve? and if so did it make a lot of difference...thanks
Im just wondering if its worth it, and i see mixed emotions scattered throughout the 1,000's of other stupid rear disc questions, and if this is a repost someone link me cause i haven't found verified information yet...thanks
You should do the Prop valve, I believe with out using the correct prop you aren't going to gain alot out of the rear disc swap...if you already have the BB and MC it wouldn't hurt but it isn't needed...if you don't you could also grab a MC off a 88-91 Prelude, is larger and you don't need to swap the BB...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac »</TD></TR><TR><TD CLASS="quote">You should do the Prop valve, I believe with out using the correct prop you aren't going to gain alot out of the rear disc swap...if you already have the BB and MC it wouldn't hurt but it isn't needed...if you don't you could also grab a MC off a 88-91 Prelude, is larger and you don't need to swap the BB...</TD></TR></TABLE>good info...yah i always got people like no you dont need any, then some like you need all and SS brake lines, just seemed kind of pointless...thanks alot
yea... if ur not running the DA bb, mc, & prop valve change it... it is also really simple to do... shouldn't take u more than 30 mins to an hour to do it all... just take out ur drivers seat & its much easier to work under the dash... & i'm 6'+
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY »</TD></TR><TR><TD CLASS="quote">Normal HF front</TD></TR></TABLE>
So then you have HF front brakes, but you are using the DA MC and BB?
If you are getting fade it is because HF front brakes are terrible. You need to upgrade. http://www.fastbrakes.com
sorry for the confusion...no i just swapped on the rear trailing arms with the DA ebrake cables...stock MC, BB, and prop valve were stock with the CRX...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">If you are getting fade it is because HF front brakes are terrible. You need to upgrade. http://www.fastbrakes.com</TD></TR></TABLE>
Modified by 89efDUSTY at 2:58 PM 3/26/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY »</TD></TR><TR><TD CLASS="quote">here we go, now someone is saying to change it all...
confusion...</TD></TR></TABLE>
i got my swap from Loserkidwac... i swapped everything.... eccept for the front brakes...
i did the bb, mc, & prop valve first... that is the easiest... honestly its not a big problem & could cost you no more than 20+ bucks at a junk yard... it cant hurt... i'm sure alot of people have done this & i would say most people who do this swap do it as well
confusion...</TD></TR></TABLE>i got my swap from Loserkidwac... i swapped everything.... eccept for the front brakes...
civic dx
Jun 25, 2003 12:38 AM
information FTW
