cel code 5 any suggestions?
Old Mar 25, 2007 | 06:12 PM
aarontrini85's Avatar
Default cel code 5 any suggestions?
im getting a code5 and a crappy idle i got a feeling its the intake manifold gasket leaking causing the map sensor to not read properly.
i have tried 2 map sensors with no change in the cars idle or drivability but if any one has any suggestions other then intake manifold gasket please let me know thanks
Old Mar 26, 2007 | 03:33 AM
Default Re: cel code 5 any suggestions? (aarontrini85)
bump
Old Mar 26, 2007 | 01:41 PM
ok well i ordered the intake manifold gasket ill post if it fixed the problem just incase some one runs in the same issue
Old Sep 28, 2010 | 12:56 PM
jdm-josh's Avatar
i also got the same prob need answers lol
Old Sep 28, 2010 | 01:14 PM
Former User's Avatar
If you hope to get help, then you must provide all relevant information about your car and engine:
https://honda-tech.com/forums/showpo...48&postcount=2
Old Sep 28, 2010 | 03:00 PM
tales sol's Avatar
if you think you have a vaccum leak, run the engine, grab a can of carb cleaner or even spray oil and spray it around anywhere that might leak, if you have a leak the engine will die down a bit when the cleaner/oil is sucked in!
always finds leaks for me!
Old Sep 28, 2010 | 04:01 PM
EJeff8's Avatar
^Or he could just do the palm test to know if he's leaking without spraying crap everywhere =D
Old Sep 28, 2010 | 04:52 PM
honda fossil's Avatar
ok u could try where he left off 3 years ago lol or you could grab some propane and move it around while watchin your o2 voltage for a sudden changes to pin point the leak.
singlecammin
Jan 20, 2011 07:20 PM
almostboostedgsr
May 11, 2009 08:21 PM
phoshyzzle
Sep 24, 2008 08:06 PM
98itr0448
Jul 10, 2004 03:17 PM
1 speedstar
Apr 16, 2003 05:25 PM
