car died while driving fuel pump not priming??? HELP!!!
okay my car died while i was driving and when i tried to start it i noticed my fuel pump wasn't priming and usually i can cause i have a walbro 190 and it's usually hella loud and not nothing. i checked for spark and had spark so that ruled out the dizzy. i decided to replace the main relay with a new one and still nothing, fuel pump still doesnt prime. i checked the grounds and all and everything seems to be okay. i have been searching online for 2 days to see what it is but no luck. does anybody know what the problem is? if everything i checked is good does this mean it's the fuel pump? thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaychi »</TD></TR><TR><TD CLASS="quote"> if everything i checked is good does this mean it's the fuel pump? thanks</TD></TR></TABLE>
can you hear the main relay click on/off as if it 'wants' to prime the pump? check for voltage going to the pump.
i have a stock fuel pump and i cant hear it allso but it works. Before i use to be able to hear the relay and pump. KNow cant hear any thing do you know what that means is it about to go bad or what.
that is so weird, my rex starting hesitating today while driving. With the accelerator fully pressed down the car started bucking (or hesitating I guess is a better word right?), also died just after starting while backing up 2 mins before. I have replaced my main relay and hear the clicking so OP I think are fuel pumps are slowly dying.
What's weird is this happened right after I did my B16 swap, I thought it was related to the motor/injectors though.
How many miles do you have OP? I have over 250K probably on fuel pump, still haven't checked it though.
OP do you have a kill switch for your fuel pump?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK_CRX »</TD></TR><TR><TD CLASS="quote">kick it if you need to drive or move your car</TD></TR></TABLE>
^^^ LOL this actually works.
My car wouldnt start at the parts store once.. a mechanic guy walks up and asked my geeked-out-office-clothed-self if i need some help with anything. I kicked the dash, started the car and said, "no thanks bud"..
Chris del sol
Apr 16, 2013 10:42 PM
93FlatBlackHatch
Dec 30, 2006 03:22 PM
