B18C block with LS Crank = Oil squirters
I know its been covered lots of times, and I read most of them, lol
this question never been covered.
ppl say for forged pistons, I don't need to Oil squirters or bend them since forged pistons are pretty much high heat resistence, so they don't need the oil to cool them down "correct if Im wrong"
I'm installing B16 pistons. and they are ceramic coated pistons, are they as reliable as forged pistons? both are high heat resistence purposes
Please Advise. Thank you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_ef9 »</TD></TR><TR><TD CLASS="quote">dont use them ls block dont have them...nither should the gsrs need them....i just installed my ge squirtter block off yesterday and they are nice
Just because the LS block doesn't have them, is that a defined conclusion as to why GS-Rs shouldn't use them? This goes with the same debate as to how LS blocks don't have a block girdle so they are unnecessary in EVERY LS/VTEC build.
At a risk of offending 90% of the forum, there's other forms of motorsport other than drag racing where the girdle is "nice" to have.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G-Harry »</TD></TR><TR><TD CLASS="quote">You cant run them with an LS crank in your GSR block. just plug them.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c »</TD></TR><TR><TD CLASS="quote">Bend them out of the way.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blu3g »</TD></TR><TR><TD CLASS="quote">I have this setup in my car now, and with my engine, the oil squirters didn't clear the crank.</TD></TR></TABLE>
If you have forged pistons, sure, block them off. But don't go telling others it doesn't work when it can and has been done before.
</TD></TR></TABLE>Just because the LS block doesn't have them, is that a defined conclusion as to why GS-Rs shouldn't use them? This goes with the same debate as to how LS blocks don't have a block girdle so they are unnecessary in EVERY LS/VTEC build.
As stated before in this thread, considering you are retaining your cast pistons, you need to have your oil squirters. Having your cast pistons ceramic coated isn't going to yield the same characteristics as a forged piston.
An LS block doesn't have oil squirters however the rod has an oil gallary that aids in cooling the oem piston.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.johnson »</TD></TR><TR><TD CLASS="quote">can you machine the crank to work with squirter's? </TD></TR></TABLE>
it would be easier and cheaper to modify the squirters
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">
it would be easier and cheaper to modify the squirters</TD></TR></TABLE>
and still be functional?
and still be functional? </TD></TR></TABLE>
https://honda-tech.com/zero...age=4
DA9tothewheel
Engine Machining & Assembly
May 23, 2016 09:25 AM
OEMJDM
13
Feb 16, 2010 04:35 PM
