What kind of Nitrous shot to put on a stock Ls/V-tec????
Old Mar 23, 2007 | 11:26 AM
KHAN SHOP's Avatar
Default What kind of Nitrous shot to put on a stock Ls/V-tec????
What kind of Nitrous shot to put on a stock Ls/V-tec without hurting the motor?
Also what kind of track times have you guys had with nos on a stock motor? Any info would help THANK YOU
Old Mar 23, 2007 | 12:55 PM
urbansi's Avatar
Default Re: What kind of Nitrous shot to put on a stock Ls/V-tec???? (KHAN SHOP)
Thats a pretty general question as far as track times go. But as far as the shot, i wouldnt run more than 20hp per cyliner, so jet it for 75 i guess.
What system are you running, and are you planning a tune?
Old Mar 23, 2007 | 01:31 PM
trickeng's Avatar
Default Re: What kind of Nitrous shot to put on a stock Ls/V-tec???? (urbansi)
50-75 shots have been reliable for us.
Old Mar 23, 2007 | 02:29 PM
s2kdre's Avatar
Default Re: What kind of Nitrous shot to put on a stock Ls/V-tec???? (trickeng)
the driver is gonna hurt the motor! u'll be good with a 100shot with the right timing and plugs.
Old Mar 23, 2007 | 02:57 PM
sc4dr's Avatar
Default Re: What kind of Nitrous shot to put on a stock Ls/V-tec???? (s2kdre)
I wouldn't run more than a 75 shot, if it's a wet setup. Do you have any idea what type of n2o kit you want, wet/dry, direct port or fogger?
Old Mar 23, 2007 | 08:05 PM
KHAN SHOP's Avatar
Default Re: What kind of Nitrous shot to put on a stock Ls/V-tec???? (sc4dr)
good info I am guessing wet shot. I took my car out to Irwindale speedway, it ran a 8.9 at 75mph I am hoping for low 8 with a 75 shot. Now I just have to purchase the kit
Old Mar 23, 2007 | 11:54 PM
KHAN SHOP's Avatar
Old Mar 24, 2007 | 08:07 AM
iUsedToBeFast's Avatar
well i was running 100 shot on a stock ls v withc itr cams and i stepped the plugs colder 2 degrees and retarded the timing 8 degrees and had a real basic vafc street tune and the car was rediculous on the streets.
Old Mar 24, 2007 | 05:32 PM
KHAN SHOP's Avatar
Default Re: What kind of Nitrous shot to put on a stock Ls/V-tec???? (iUsedToBeFast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iUsedToBeFast &raquo;</TD></TR><TR><TD CLASS="quote">well i was running 100 shot on a stock ls v withc itr cams and i stepped the plugs colder 2 degrees and retarded the timing 8 degrees and had a real basic vafc street tune and the car was rediculous on the streets.</TD></TR></TABLE>
Old Mar 24, 2007 | 05:53 PM
sc4dr's Avatar
Thats really conservative for a 100 shot.
Old Mar 25, 2007 | 10:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sc4dr &raquo;</TD></TR><TR><TD CLASS="quote">
Thats really conservative for a 100 shot.</TD></TR></TABLE>
i would rather be safe then sorry. and if your fast and conservative then your in the clear..
Old Mar 25, 2007 | 01:37 PM
KHAN SHOP's Avatar
ttt
Old Mar 25, 2007 | 01:53 PM
92LSVTEC's Avatar
i rocked a dry 75 shot on my stock lsvtec @ 58k, car still ran strong when i took it apart at 79k... had it tuned all motor, did a few nitrous pulls, changed the FPR jet, 218 whp @ 7400... the longevity of that setup was due to the 7600 rev limiter
Old Mar 26, 2007 | 12:10 AM
KHAN SHOP's Avatar
Default Re: What kind of Nitrous shot to put on a stock Ls/V-tec???? (92LSVTEC)
75 shot it is!!!
Old Mar 26, 2007 | 05:05 AM
B16A1-EF9's Avatar
What about an LS/V with B16 PR3 pistons, compression is in the 12-12.5:1 range. What do you guys recommend as the most hp shot to go with?
Old Mar 26, 2007 | 10:05 AM
KHAN SHOP's Avatar
Default Re: (B16A1-EF9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A1-EF9 &raquo;</TD></TR><TR><TD CLASS="quote">What about an LS/V with B16 PR3 pistons, compression is in the 12-12.5:1 range. What do you guys recommend as the most hp shot to go with?</TD></TR></TABLE>
????????? very interested to know too
Old Mar 26, 2007 | 10:19 AM
with pr3's your compression is in the 11.3 to 11.5 nowheres near the 12's even with a gsr head. you can run 100 shot with a good tune on that set up too..
Old Mar 30, 2007 | 11:51 PM
KHAN SHOP's Avatar
Default Re: (iUsedToBeFast)
Old Apr 1, 2007 | 12:28 AM
KHAN SHOP's Avatar
Default Re: (KHAN SHOP)
any more info???
jdmjunkie8
Jul 18, 2007 02:11 PM
DIS-1
Mar 19, 2007 05:36 PM
BME1986
Jun 16, 2004 12:16 PM
HondaLife
Mar 4, 2003 08:29 PM
NewbieGuy
Oct 11, 2001 08:24 AM
