Syncros problems.
Old Mar 21, 2007 | 07:31 AM
Mr.Death's Avatar
Default Syncros problems.
I have the ever so common 3rd gear grind in my ZC LSD tranny. Does anyone have a write up or "how to" regarding fixing the problem. I have a spare tranny form a z6 with the same problem and I plan on using it for practice before attemting the procedure on the ZC tranny. Thanks
Rick
Old Mar 21, 2007 | 08:07 AM
ludesrv's Avatar
Download the honda manual for a CRX of honda-hookups.com and buy new syncros, bearings and spacers from honda, then go give her.
At the same time I recommend a HF 5th gear set for your install. Might aswell make so highway MPG happen if your in there and it's all apart.
Old Mar 21, 2007 | 08:54 AM
slowcrxsib16's Avatar
my s1 tranny was grinding bad in 3rd gear, one night coming home from work, a gear came out of the transmission on the road... sucked big time, good luck on it man
Old Mar 21, 2007 | 09:26 AM
Ermil's Avatar
Default Re: (slowcrxsib16)
You could always try these.
Old Mar 21, 2007 | 09:35 AM
ChickenH's Avatar
ive seen some people on here in the past polish the burs off the syncros and collars.
Diffrent fluids make a radical diffrence. so if your not using Honda MTF try something else.
Old Mar 21, 2007 | 10:07 AM
snm95ls's Avatar
Default Re: (ChickenH)
Honda MTF does make a huge difference. I made the mistake of running synthetic 30 weight after the swap in my YS1 (that I rebuilt last summer) and it started grinding terribly during regular driving. I decided to change out the transmission fluid for the Honda MTF and the grinds are gone.
I never thought it would make that much difference, but it does.
Old Mar 21, 2007 | 08:56 PM
Mr.Death's Avatar
Default Re: (snm95ls)
So far I've tried Honda MTF, GM syncromesh and Royal purple Syncromesh. No luck thus far.
Old Mar 21, 2007 | 09:08 PM
crazykamper's Avatar
hmm, donno if its my syncros. BUT, i do have a hard time getting it into gears sometimes... no grinds at all, just have to shove it into gear with some persuasion sometimes.... BUT, if i put it in reverse, (before going into first....) then it goes in nice and smooth... maybe i might try the honda mtf....
Old Mar 21, 2007 | 09:25 PM
hatchback64's Avatar
Casto sinthetic blend 10 40 fixed my 2nd gear grind in my turbo 92 si.
Old Mar 21, 2007 | 11:25 PM
Zaakro's Avatar
Default Re: (hatchback64)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchback64 &raquo;</TD></TR><TR><TD CLASS="quote">Casto sinthetic blend 10 40 fixed my 2nd gear grind in my turbo 92 si. </TD></TR></TABLE>
do not use synthetic oil in your transmission. Use Honda MTF, GM synchromesh, or 10w30 oil non-synthetic.
wallawee
Jul 29, 2006 05:43 PM
OliGSR
May 27, 2005 06:14 PM
MarkZeroNine
Sep 29, 2004 11:16 AM
thexiong
Apr 8, 2003 09:57 AM
crxdevelop
Feb 24, 2003 09:47 PM
