Grind into 3rd
Old Sep 27, 2004 | 07:35 AM
MarkZeroNine's Avatar
Default Grind into 3rd
Well I just bought my GS-R and it was a one owner(couple.) obviouslly the woman didnt know how to drive(not to make assumptions or anything lol).. but i just replaced the clutch. If you're under 5k(rpm) its really smooth, above that it will barely grind into third. i can avoid high rpms, but i'd rather not . do i need a whole new tranny or what?
Old Sep 27, 2004 | 07:44 AM
furious94ls's Avatar
Default Re: Grind into 3rd (MarkZeroNine)
3rd gear syncro. It's common. You can either replace the syncros (expensive), replace the tranny (expensive)
First thing I would do is change the MTF with some Honda MTF. That should help, if it is still there then I would drain it out again and use a mix of Honda MTF and GM syncromesh friction modified.
Old Sep 27, 2004 | 08:08 AM
luvinmyGSR's Avatar
Default Re: Grind into 3rd (furious94ls)
i have the same problem and im looking into the syncromesh fm myself...heard it works really good...like the above post 3rd gear grinds are common in the teg...
Old Sep 27, 2004 | 09:08 AM
bsballboyjk's Avatar
Sorry to hear it, just happened to my friends civic. he took it in and they told him he needs a whole new tranny... good luck though!
Old Sep 27, 2004 | 12:16 PM
Default Re: (bsballboyjk)
thanks for the replies. where do i get the gm stuff?
Old Sep 27, 2004 | 12:18 PM
ebelp's Avatar
Default Re: (MarkZeroNine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MarkZeroNine &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the replies. where do i get the gm stuff?</TD></TR></TABLE>
From a GM dealer (Chevrolet, Cadillac, Pontiac, etc.). Beware though, this stuff isn't cheap...my local Chevy dealer quoted me $12.47/quart. btw, the part number for the GM Synchromesh w/ Friction Modified is #12377916.
Old Sep 27, 2004 | 12:31 PM
Default Re: (ebelp)
better than replacing syncros or a tranny.. haha. how many quarts do i need?
Old Sep 27, 2004 | 01:16 PM
Built B18ABorC's Avatar
Default Re: Grind into 3rd (luvinmyGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luvinmyGSR &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem and im looking into the syncromesh fm myself...heard it works really good...like the above post 3rd gear grinds are common in the teg...</TD></TR></TABLE>
I put syncromesh in every tranny that had a slight grind and it always worked for me.
Old Sep 27, 2004 | 01:24 PM
Default Re: Grind into 3rd (Built B18ABorC)
i'm feeling relieved!
Old Sep 27, 2004 | 01:27 PM
svtec's Avatar
L D E S
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MarkZeroNine &raquo;</TD></TR><TR><TD CLASS="quote">i'm feeling relieved!
how many quarts do i need?</TD></TR></TABLE>
buy three because the tranny takes between 2.5-3.00 quarts.
Old Sep 27, 2004 | 04:17 PM
B2FiNiTY's Avatar
Default Re: Grind into 3rd (svtec)
Actually 2.1 but you need 3 bottles regardless.
Old Sep 27, 2004 | 04:32 PM
svtec's Avatar
L D E S
Default Re: Grind into 3rd (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Actually 2.1 but you need 3 bottles regardless. </TD></TR></TABLE>
that's what my helms says, but for some reason it seems like usually i put in around 2.5 quarts.
Old Sep 27, 2004 | 05:10 PM
thanks guys.. so just fill it up w/ gm, nothing else?
Old Sep 29, 2004 | 11:16 AM
svtec's Avatar
L D E S
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MarkZeroNine &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys.. so just fill it up w/ gm, nothing else?</TD></TR></TABLE>
that is it...
rena
18
Apr 5, 2007 12:51 PM
qazaq
Sep 7, 2006 04:34 AM
wallawee
Jul 29, 2006 05:43 PM
Ricta
Jul 1, 2005 01:11 PM
allmotorb17a
Feb 2, 2004 07:09 PM
