b18b swap questions
Old Mar 20, 2007 | 05:59 PM
pine_apple45's Avatar
Default b18b swap questions
i have searched around this forum and didnt find the right information i needed.
i have a 96 civic ex and im in the process of swaping in a OBD1 b18b motor but have a few things taht concern me.
i have a obd2 ecu from a b18band was wondering will that work? also, do i have to get a LS engine harness or can i use a different harness? friend told me i can use a dx harness. is that true?
i would apreciate all the help and information. been waiting for about 8 months for a freinds to help me get my car running but i dont think i can wait ne longer so i decided to do the swap myself.
Old Mar 20, 2007 | 06:08 PM
lilgryeg's Avatar
Default Re: b18b swap questions (pine_apple45)
As long as the ecu is obd2a you should be able to use it. Also the harness in your car should be able to be used.
Old Mar 20, 2007 | 06:09 PM
Default Re: b18b swap questions (lilgryeg)
so the obd2 ecu will work with the obd1 motor?
Old Mar 20, 2007 | 06:16 PM
Boostedb20EH2's Avatar
Im almost positive you will need a conversion harness.
Old Mar 20, 2007 | 06:20 PM
lol..now im confused..so i do needa get a new harness? or stick with waht i got?
Old Mar 20, 2007 | 06:22 PM
pdiggitydogg's Avatar
Obd2 ls engines have a knock sensor, obd1 do not - you'll throw a code for that. So...get an obd1 P75 ecu and conversion harness
Just use the current civic engine harness though - you will only need to extend IAT to the intake manifold and EVAP - no need to get another harness. There will be a few extra connectors, but just bag/tie them so they dont get wet.
I hope you have the correct mounts.
edit**
Oh, if you want to add a knock sensor and use the obd2a ecu, Ive been told people re-tap the upper-inner alternator mount hole for a sensor there.
Old Mar 20, 2007 | 06:37 PM
Default Re: (pdiggitydogg)
man..this swap is starting to b a pain..
Old Mar 20, 2007 | 06:40 PM
Default Re: (pine_apple45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pine_apple45 &raquo;</TD></TR><TR><TD CLASS="quote">man..this swap is starting to b a pain..
Ha no ****
Old Mar 20, 2007 | 07:27 PM
man the obd1 p75 ecu is pricey..anyone know where i can buy one without burning a hole in my pocket?
Old Mar 20, 2007 | 07:34 PM
Honda-tech or junkyard. But HT will be cheaper.
Old Mar 20, 2007 | 08:10 PM
where are you looking???
There are several on ebay right now, almost all under $100
Old Mar 20, 2007 | 08:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">where are you looking???
There are several on ebay right now, almost all under $100</TD></TR></TABLE>
here on HT..they want 140-150 for em..sad day..
j4s0n1337
19
Jul 21, 2019 06:47 PM
itzyaboyzeem03
Dec 5, 2008 12:37 PM
mr. goodwrench
Jun 9, 2008 04:22 PM
slo_ej8
Jul 12, 2007 09:12 PM
4thgenlude
13
Oct 24, 2006 10:46 AM
