what to use as assembly lube/ head stud lube?
Old Mar 20, 2007 | 01:50 PM
SHG_EasyE's Avatar
Default what to use as assembly lube/ head stud lube?
Hey guys, im going to be rebuilding my B18 and im wondering what i should use for an assembly lube, also what i could use for my rod bolt and head studs. the rob bolts are new, but ive heard to not use the supplied moly lube. As far as the head studs, I got golden eagle's used from a freind, therefore i dont have the moly supplied by golden eagle. Ive seen people using redline oil, what are they referring to? their engine oil or a special machine oil? any help is gretly appreciated
Old Mar 20, 2007 | 01:56 PM
DonF's Avatar
Default Re: what to use as assembly lube/ head stud lube? (SHG_EasyE)
K-Y great lubricant.
Old Mar 20, 2007 | 02:02 PM
Rocket's Avatar
Default Re: what to use as assembly lube/ head stud lube? (DonF)
1. OEM torque settings are based off of using engine oil.
2. ARP, Aftermarket bolts, use the lube provided/recommended with the product and follow the torque spec instructions. Not follwing this will disastrously harm your engine and it will not be the manufacturers fault (and they do know how to check if you fuckit up). I have had many conversations with Cunningham rods about this.
Old Mar 20, 2007 | 02:03 PM
92TypeR's Avatar
FSAE
Default Re: what to use as assembly lube/ head stud lube? (Don Lackey)
Torco Moly based assembly lube.
Old Mar 20, 2007 | 08:18 PM
Natural Aspirations's Avatar
I am currently using Redline assembly lube.
Old Mar 20, 2007 | 09:25 PM
drift4jesus's Avatar
Default Re: (Natural Aspirations)
ARP supplied moly lube on fasteners
Manton assembly lube when putting top ends together.
Old Mar 20, 2007 | 10:56 PM
SHG_EasyE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Natural Aspirations &raquo;</TD></TR><TR><TD CLASS="quote">I am currently using Redline assembly lube.</TD></TR></TABLE>
so redline makes a special assembly lube? i just contacted golden eagle to see what they suggest to use
Old Mar 21, 2007 | 02:47 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: (SHG_EasyE)
do you lube everything, bolts, dowels, surfaces, rocker arms, lobes, etc etc ??
Old Mar 21, 2007 | 07:20 AM
Bisimoto's Avatar
Default Re: (GarageAlchemist)
Torco assembly lube, here.
Old Mar 22, 2007 | 12:03 PM
C_Rock77's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">K-Y great lubricant.</TD></TR></TABLE>
For some things.....
Don, is there something you want to share w/ the board?
Old Mar 22, 2007 | 01:12 PM
alterdcreations's Avatar
Default Re: what to use as assembly lube/ head stud lube? (C_Rock77)
he might need extra lube for the main crank seal lol
SPOOLINmatt
Feb 10, 2013 06:29 AM
crvtkllr
Mar 29, 2007 01:00 PM
BlueShadow
Aug 15, 2005 12:27 PM
unknown2
Jun 13, 2004 08:56 PM
crxhybrid1320
Jan 10, 2003 12:49 PM
