Coolant spilt out...do I need to rebleed it?
Old Mar 20, 2007 | 12:21 PM
invisible's Avatar
Default Coolant spilt out...do I need to rebleed it?
one of my radiator hoses popped off cuz the dumb clamp wasn't all the way on. some spilt out from the thermostat hose. if i refill it up, do i need to rebleed it? can i "mix" coolant? i used honda coolant but don't have anymore, but i have another brand coolant here. can i use it?
Old Mar 20, 2007 | 12:35 PM
philosofy1's Avatar
Default Re: Coolant spilt out...do I need to rebleed it? (.hue)
as long as it's coolant is for your car (and not that orange crap GM uses) then you're fine.
Old Mar 20, 2007 | 12:40 PM
invisible's Avatar
Default Re: Coolant spilt out...do I need to rebleed it? (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">as long as it's coolant is for your car (and not that orange crap GM uses) then you're fine. </TD></TR></TABLE>
i have some random brand, i think my dad bought it. its valucraft?
Old Mar 20, 2007 | 12:44 PM
Maireeka's Avatar
check to see if it's 50 50 mix, or if you need to mix it with water as well.
Old Mar 20, 2007 | 12:46 PM
invisible's Avatar
Default Re: Coolant spilt out...do I need to rebleed it? (Maireeka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maireeka &raquo;</TD></TR><TR><TD CLASS="quote">check to see if it's 50 50 mix, or if you need to mix it with water as well.</TD></TR></TABLE>
i dont think it is, ill do it then. not that much spilled out so i should be good?
Old Mar 20, 2007 | 02:13 PM
95ProjectEJ1's Avatar
You should be fine, just take the cap off and "burp" the system if you want. Just make sure its not a 50/50 mix when you go to put more fluid/water in.
Old Mar 20, 2007 | 03:05 PM
invisible's Avatar
Default Re: Coolant spilt out...do I need to rebleed it? (95ProjectEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">You should be fine, just take the cap off and "burp" the system if you want. Just make sure its not a 50/50 mix when you go to put more fluid/water in. </TD></TR></TABLE>
Wait, make sure it's not premixed? So I don't need to mix it with water then?
Old Mar 20, 2007 | 03:15 PM
Kafelatte's Avatar
if your that worry about it. drain the radiator and refill it with a new bottle of coolant. only $10. or if it's warm where you live just add water since you have some coolant in it already. you don't need alot of antifreeze unless you live in alaska or some place really cold.
Old Mar 20, 2007 | 04:57 PM
invisible's Avatar
Default Re: Coolant spilt out...do I need to rebleed it? (kay20adc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kay20adc2 &raquo;</TD></TR><TR><TD CLASS="quote">if your that worry about it. drain the radiator and refill it with a new bottle of coolant. only $10. or if it's warm where you live just add water since you have some coolant in it already. you don't need alot of antifreeze unless you live in alaska or some place really cold.</TD></TR></TABLE>
im in texas haha.
Old Mar 20, 2007 | 07:43 PM
You just can't add water/more coolant to a 50/50 mix. Make sure you add in the same stuff you put in
vroomboom
Honda Civic (2001 - 2005)
May 22, 2008 04:44 AM
ordale
Feb 5, 2008 06:24 PM
tianporn
Feb 17, 2005 11:03 PM
MikeyDB7
Jan 21, 2004 11:04 PM
benmasters
May 25, 2003 12:47 PM
