had my car tuned over the weekend...
setup-
stock jdm gsr from the head gasket down
arps & cometic .071 gasket
63 trim gt35r
neukin ram horn
tial 38mm waste gate
3 inch dp & 3 inch thermal exhaust
blox spec a cams with skunk gears
hondata s200b
venom 990cc injectors
blox intake mani
tuned by suprdave
this was on 14psi and 93 octane pump gas
the highest it made was 362whp and 260wtq
Modified by jdmef-9 at 6:47 PM 3/20/2007
63 trim gt35r
neukin ram horn
hondata s200b
blox intake mani
tuned by suprdave
is that a T3? that thing spools crazy fast. good numbers!
were u using a 38mm wastegate? had any problems with boost spiking/dropping? the top end is a little bouncy
i needed a new cap and rotor the humps u c are nearly misfires but its all good i got new oem stuff... yes its a t3 gt35r... and my compression is low 9.6:1
oh and as for the wastegate question im using a tial 38mm with no problemes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 »</TD></TR><TR><TD CLASS="quote">ball bearing? journal?</TD></TR></TABLE>
gt35r = BB
gt35r = BB
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmef-9 »</TD></TR><TR><TD CLASS="quote">i needed a new cap and rotor the humps u c are nearly misfires but its all good i got new oem stuff... yes its a t3 gt35r... and my compression is low 9.6:1
It says in the first post its a jdm gsr which I think the compression is like 10:6:1 or something in that range? Im guessing you have a thick headgasket?
</TD></TR></TABLE>It says in the first post its a jdm gsr which I think the compression is like 10:6:1 or something in that range? Im guessing you have a thick headgasket?
14lbs with cams similar to a type r and still only 360 hp?
just doesnt sound like its up to the turbos potential, i have seen people hit that much power on gsr cams and 9-10lbs of boost..
i hit 366whp on 10lbs with my LS/VTEC on my GT35R.... but its T4.
i would take it back to get retuned since u fixed the dizzy. i tuned a car that had a bad dizzy with the same symptons u were having. it was an all motor car. with the bad dizzy it made 180whp. with a new one installed w/o any tuning, the car made 216whp
