Please Help Me Diag a Grinding Noise.
Old Mar 19, 2007 | 02:41 PM
MatrixShark's Avatar
Default Please Help Me Diag a Grinding Noise.
Here's my issue: When turning left at any speed, there is a grinding noise. It happens with the clutch in or out, while braking or accelerating. The noise is faint at all times but get's real bad when I turn left. It sounds to me like it is coming from the R/FR area. So far I've kind of been throwing parts at it trying to fix it.
I thought it was the R/FR axle and replaced it with a new one. That made zero difference. Also the right front wheel bearing went bad back in october (I had a new one put in) and that noise was completely different from this new noise. The wheel bearing noise was a howling moaning noise that would come and go as I shifted the weight of the car left and right. This new noise is a rubbing/grinding noise that kind of goes whomp whomp while the wheel is turned... even at 1mph. I've had my calipers checked and my rotors resurfaced. That did nothing. I've checked the splash shield to maked sure nothing is rubbing. I hate to say it but, I'm starting to think it may be a bearing in the tranny. Any help on this is GREATLY appreciated. Thanks in advance.
Old Mar 20, 2007 | 04:29 AM
Just checking in to see if anyone has any advice...
Old Mar 20, 2007 | 04:33 AM
RTW DC2R's Avatar
put the car on jackstands, turn the wheels to the left, and spin the wheels. try all the gears and neutral, and see if you can duplicate the problem.
Old Mar 20, 2007 | 04:50 AM
mpd076's Avatar
Default Re: Please Help Me Diag a Grinding Noise. (MatrixShark)
I just had a similar problem and it was because the tranny had the wrong fluid in it. Replaced with correct mtf fluid and it's gone. When turning left or right at low speed it would woom-woom-woom. It would also click a little bit when moving off at start. Good luck.
Old Mar 20, 2007 | 05:18 AM
tartje's Avatar
Default Re: Please Help Me Diag a Grinding Noise. (mpd076)
don't suppose it could be your diff?
Old Mar 20, 2007 | 12:13 PM
I will try a tranny fluid flush... let's see what happens.
Old Mar 21, 2007 | 07:12 AM
Default Re: (MatrixShark)
Just picked up 3 qts. of GM Synchromesh. I'll update after it's in the car.
Old Mar 21, 2007 | 07:20 AM
RTW DC2R's Avatar
GM Synchromesh
but...unless there was no fluid in there to begin with, I cant see changing fluid fixing this problem. it would be loud all the time, not just while making a left hand turn and making a rubbing sound.
are you sure it just not your tire on your fender liner
Old Mar 21, 2007 | 07:45 AM
mpd076's Avatar
Default Re: (I love lamp.)
The LSD whining/moaning on low speed turn has been around for a while. Caused by wrong grade oil. Not saying that's it for sure, but it was my problem.
https://honda-tech.com/zerothread?id=71028
https://honda-tech.com/zerothread?id=503180
Old Mar 21, 2007 | 11:10 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I love lamp. &raquo;</TD></TR><TR><TD CLASS="quote">...are you sure it just not your tire on your fender liner </TD></TR></TABLE>
Yeah, I checked that out pretty thoroughly. It makes the noise all the time but it's very subtle until I turn left. Then it get's real loud.
Old Mar 22, 2007 | 12:23 PM
OK. The fluid flush is done and the noise is much better. It's still there but it's like one tenth as loud. I will update as the fluid works it's way in.
Old Mar 22, 2007 | 01:59 PM
mpd076's Avatar
Cool. Mine still makes it occassionally as well and that's 6 days after replacing it. Before I could repeat it by turning slowly in a circle and accelerating slightly, but doing that now makes no noise.
Old Mar 23, 2007 | 04:26 AM
It seems to be slightly better each time it sits and then I drive it again. It's already much better. I have to really turn (at around 5mph) sharp left to make the noise now. Hopefully with a little more time, that will go away as well.
I wonder... Does anyone recommend a second flush after a few weeks or so? The synchromesh fluid ran me about $30 for the three qts (It took roughly two and a third). I don't mind spending money but, I really hate WASTING it.
Old Mar 23, 2007 | 01:33 PM
tireiron's Avatar
gm syncro mesh is great! poinless comment ahooo!
RacerTim
Apr 6, 2010 08:12 AM
lessum
Feb 28, 2010 02:43 PM
sporty240
Nov 10, 2008 02:55 AM
Sammo115
Suspension & Brakes
Jan 2, 2008 09:41 AM
