ITR P73 problem
Old Mar 22, 2007 | 03:52 PM
civic6's Avatar
Default ITR P73 problem
Im trying to get my car to pass somg I ordered a P73 ecu so the smog station can read the car I have a 2000 ITR
the ecu i got is 37820-P73-A04
I installed it and the car didnt want to turn over? any advise would be great! thx 4 your time !
Old Mar 22, 2007 | 03:57 PM
civic6's Avatar
Default Re: ITR P73 problem (civic6)
and I also noticed that the ecu is the same size as the JDM ecu's smaller than some i seen, let me know thanks!
Dave_B's Avatar
Is it an 00-01 ECU? If so, it probably has the immobilizer still installed. You would have to remove that for it to work with your key.
Old Mar 22, 2007 | 03:58 PM
ZygSpeed's Avatar
Did you get the dealer to make a key for you to use with that ECU?
Hmmm ... JDM ECU on a USDM car?
Old Mar 22, 2007 | 05:14 PM
civic6's Avatar
Default Re: ITR P73 problem (zygspeed)
no i didnt get a key made with it when I bought it the person selling it said its for a USDM ITR and 200 itr would work with it thanks for your info gusif more please help thx!!
Old Mar 23, 2007 | 04:12 AM
MatrixShark's Avatar
The immobilizer looks for a matched/programmed key and will not fire up the engine without "finding" it.
Old Mar 23, 2007 | 02:37 PM
vtec.dc2's Avatar
you can remove imobilizer chip from ecu but.. it will fail due to check engine light. i think theres a way to bypass that so you do not get cel i sure dont know how to.
the only way to make that ecu work and not throw cels is.. to go to dealer and have them reprogram that ecu to work with your ignition. call them up and aks someone who knows
Old Mar 23, 2007 | 02:52 PM
stolen_rims's Avatar
these guys can remove the immobilizer for $55usd ->http://www.ff-squad.com/ecu/imm.removal.htm
If you think a usdm 94'OBD1 p72 will work I can let you borrow mine as Im being deployed for a couple weeks soon(I'd want to hold something of equal value during the time I'd be lending it).
Old Mar 23, 2007 | 03:11 PM
neo_'s Avatar
Default Re: ITR P73 problem (stolen_rims)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stolen_rims &raquo;</TD></TR><TR><TD CLASS="quote">these guys can remove the immobilizer for $55usd -&gt;http://www.ff-squad.com/ecu/imm.removal.htm
You can remove it yourself with basic soldering knowledge. Their method is nothing special, it even states in their FAQs that there will still be a CEL.
"Once an IMM is removed you will have a constant check engine light, because the factory programming is designed to look for the IMM, and now that it's been removed, it throws a check light letting the driver know something has changed."
twinj
Apr 9, 2007 09:50 AM
stas_nx
Feb 12, 2005 06:07 AM
turkdog
Nov 30, 2003 06:15 AM
Duck Sauce
Dec 12, 2001 01:58 PM
