What exactly is a "domelight supervision" ?
Old Mar 19, 2007 | 08:06 AM
stephen_civic98's Avatar
Default What exactly is a "domelight supervision" ?
On the 5900sst on the h1 harness, there is a black/white wire that is the domelight supervision output. What is wire supposed to do when I arm/disarm the system? Is the domelight post to come on and then off? If so its not doing that, is it b/c I need a relay hooked up to my domelight wire? I'm tapping my black/white wire into the light green with red stripe wire.
my car is a 1998 honda civic DX 4dr.
Alarm is the Viper 5900 sst
Old Mar 19, 2007 | 01:13 PM
advert's Avatar
Default Re: What exactly is a "domelight supervision" ? (stephen_civic98)
that wire needs a realy to work
its just to make your light come on when you disarm your alarm.
Old Mar 19, 2007 | 01:58 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: What exactly is a "domelight supervision" ? (advert)
Unplug that wire asap before you burn out that circuit. It will not support the current draw to turn on the dome light. You will see the light really dim if you do it. You must use a relay to hook up the dome light. It will also flash when the alarm goes off
Old Mar 20, 2007 | 05:31 AM
jz98ctr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advert &raquo;</TD></TR><TR><TD CLASS="quote">that wire needs a realy to work
its just to make your light come on when you disarm your alarm. </TD></TR></TABLE>
X2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">Unplug that wire asap before you burn out that circuit. It will not support the current draw to turn on the dome light. You will see the light really dim if you do it. You must use a relay to hook up the dome light. It will also flash when the alarm goes off</TD></TR></TABLE>
X2
Old Mar 20, 2007 | 05:35 AM
jz98ctr's Avatar
Default Re: What exactly is a "domelight supervision" ? (jz98ctr)
the black/white needs to be hooked up to a SPDT relay to work properly.
hook the black/white up the pin 85
hook the constant 12v+ to pin 86
hook up ground to the pin 87
hook up your door trigger to pin 30
here's a link with a diagram
http://www.the12volt.com/relays/relays.asp
it should work
o_0
Audio / Security / Video
Dec 12, 2010 09:36 AM
djslim23
Sep 13, 2010 07:54 PM
fastcrvi
Nov 16, 2007 08:19 AM
superthug
11
Oct 23, 2006 04:21 AM
jwork101
Mar 26, 2004 07:54 PM
