Parking Light Flash Wire?
Old Jul 10, 2002 | 08:54 PM
jwork101's Avatar
Default Parking Light Flash Wire?
Hey Guys, I installed my Clifford Alarm a while back, and never knew what wire was for the parking light flash. Does anyone know what this wire is and a detailed explanation of where it is? I tried doing a search but didnt come up with anything.
Thanks
Jim
Old Jul 10, 2002 | 09:05 PM
o_Rage_o's Avatar
Default Re: Parking Light Flash Wire? (jwork101)
I don't personally know the exact color code, but the wire will give out a low current pulsed output to activate the parking lights.
This wire will NEED to be connected to a relay, because its low current and the alarm was not designed to power the lights (ditto if installing courtesy light)
Please also install a diode inline with the parking light wire, and any other flashing light outputs to prevent certain methods of disabling the system.
-Rage
Old Jul 10, 2002 | 09:37 PM
brinks's Avatar
go here, look it up:
http://www.bulldogsecurity.com/wiringdiag.htm
Old Jul 11, 2002 | 10:12 AM
ITACivic's Avatar
the alarm has wire details on the brain itself.
Old Jul 11, 2002 | 02:12 PM
GSRaCeRbOI's Avatar
are you asking what color wire/location it is for the parking wire on your car (which you didn't specify what you drive).. or are you asking which wire from the alarms wiring harness is the parking light flasher wire? what model # Clifford do you have?
Old Mar 26, 2004 | 07:54 PM
F.C.DragSports's Avatar
Default Re: Parking Light Flash Wire? (GSRaCeRbOI)
red and black wire above fusebox hope that helps. Finishing the install right now.
djslim23
Audio / Security / Video
Sep 13, 2010 07:54 PM
fastcrvi
Nov 16, 2007 08:19 AM
stephen_civic98
Mar 20, 2007 05:35 AM
superthug
11
Oct 23, 2006 04:21 AM
gsr18cx
Sep 28, 2004 12:19 PM
