blow off valve stuck open???
Hey guys i have a cheap pos blow off valve from ebay....
i know, i should stick with name brand but, it took a crap and i am wondering if this happened to anyone and if there is a way to fix those things
i just posted the same post.... i took my ssac wastegate apart and just cleaned and lubed it and it works great.. if its like my bov then it should be reall easy
two thumbs up for ssac kits
it could be that u got a weak spring in there....my friend had the same problem with his tial bov staying open between shifts, it was fixed when he put in a 11lb spring
From: What Business is it of yours where Im from Friendo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FUCATYPR »</TD></TR><TR><TD CLASS="quote">Is it a RFL knockoff?</TD></TR></TABLE>
Yea...what kind of knock bov is it?
My brother had a genuine RFL BOV and he said that every couple of months you have to take it apart and regrease it so it doesn't get stuck. Just keep it greased up so it doesn't get stuck.
Hope that helps.
Hope that helps.
