Can I test my TDC/CKP sensors?
Old Mar 17, 2007 | 10:25 AM
boostinh2x's Avatar
Default Can I test my TDC/CKP sensors?
Title says it.
How would i test the two sensors that read off the crank on an OBD2 h22?
Old Mar 17, 2007 | 12:45 PM
kulrevon's Avatar
Default Re: Can I test my TDC/CKP sensors? (boostinh2x)
each sensor should have 350-700 ohms between the terminals for each sensor.
The should be no continuity between the body of the dizzy and the terminals.
Old Mar 17, 2007 | 01:47 PM
boostinh2x's Avatar
Default Re: Can I test my TDC/CKP sensors? (kulrevon)
what does the distributor have to do with it? this is for an obd2 application where the sensors are on the oil pump housing.
Old Mar 20, 2007 | 04:09 AM
kulrevon's Avatar
I should be the same ohms. and instead of to the dizzy just see between the terminals and the oil pump.
Legitwerks
Sep 25, 2018 07:51 PM
teg00blk
Mar 24, 2010 09:46 AM
street_ride14
Mar 2, 2009 09:17 AM
kornerk12
Nov 30, 2007 04:58 AM
boostedcrx
Oct 17, 2002 05:03 PM
