obd1 question
Old Mar 16, 2007 | 07:02 PM
BlueRex1020's Avatar
Default obd1 question
so i coverted my rex to obd1 a while ago n i got some codes n i jus got the 2 wires added to my jumper harness so i can check my codes on my dash like eg's....i get the code for 02 sensor n IAT i think.....is it because i have to rewire those sensors to obd1? if so are there any other sensors that need to be rewired to obd1?....im runing an mpfi dx n i coverted to obd1 using a jumper harness, p06 ecu, n obd1 dx dizzy....
Old Mar 16, 2007 | 08:36 PM
Default Re: obd1 question (BlueRex1020)
bump..
Old Mar 17, 2007 | 07:48 PM
anyone?
Old Mar 17, 2007 | 07:53 PM
Rywire's Avatar
Iat... I bet you used the tandem valve plug, in the iat location. Make sure you have a red/yel and green/wht in the iat location
Old Mar 17, 2007 | 07:56 PM
Default Re: obd1 question (droppedcrxsi)
nevermind the codes are for 02 sensor n map sensor...do i have to rewire my 02 sensor? wat about the map sensor?
Old Mar 17, 2007 | 08:04 PM
4thgenhtch's Avatar
yes you need to wire for a four wire o2 sensor
Old Mar 17, 2007 | 08:13 PM
Default Re: obd1 question (4thgenhtch)
wat about the map sensor? could jus be a bad map sensor?
Old Mar 17, 2007 | 09:28 PM
4thgenhtch's Avatar
Yea my buddies car just today threw a code for a bad map sensor... Cant hurt to try a new one out, If your sure your wirings good to the sensor
Joey Mitchell
Dec 5, 2018 09:02 PM
88Hatchy
Jun 1, 2009 10:20 PM
MDPL8706
Jul 12, 2006 06:31 PM
menappi
Jul 2, 2006 06:31 PM
MugenHonda
Jun 27, 2005 12:12 PM
