Question about the problems encoutering and plaguing me
Location: With my POS D15B2, Whereever whenever, United States
OK, I finally was able to check my codes, 41 and 3.
Well it turns out, I had a obd2 and obd1 map sensor, in which the obd2 map sensor was on the fire wall and the original map sensor was on the throttle body of the z6. The guy that owned the car before must have screwed around with the wiring because when I switched the map sensor plugs, the car idles perfectly and eliminated the map sensor cel.
Now I just have a 41 which is the primary oxygen sensor.
Can it be that my oxygen sensor is not wired up correctly?
I was told from bauley that the dx is a 4 wire oxygen sensor and I had 3 oxygen sensors, 2 which I have tried are bad?
thanks
This is a obd1 z6 plugged directly in the dx harness at the shock towers and the 3 wires for the vtec solenoid have been ran properly
thanks
thanks
thanks
