ls vtec question
Old Mar 16, 2007 | 06:02 PM
geoffroy's Avatar
Default ls vtec question
i am ready to start my build. got the head, proper ecu and wiring harness, proper water pump and timing belt. the vtec oil passage is plugged in the head and i've got my ls vtec oil piping kit.
i'm using an 1997 b18b block....this block does not have an oil breather at the back of the block...
i wanted to know if there is an economical way do 'make one' or bypass one?
thanks,
jeff
Old Mar 16, 2007 | 08:59 PM
CRX 2.0V-T's Avatar
Default Re: ls vtec question (geoffroy)
gotta use oil catch can.
Old Mar 17, 2007 | 03:59 AM
geoffroy's Avatar
Default Re: ls vtec question (CRX 2.0V-T)
yeah but the hole in the b18b where the oil catch can hooks up to is blocked on my 97 bloc. I've done a search and cant come up with anything...
i saw an oil catch can on ebay but i dont know if this is what i need to get... i dont think it is
http://cgi.ebay.com/ebaymotors...ZWDVW
Old Mar 17, 2007 | 04:20 AM
geoffroy's Avatar
ok, i did some more research and i know how to fix it up. i will unscrew the plug that is on the right of my oil filter and get the plug off a 97 prelude. this plug has a nipple on it so i will be able to connect a line from this nipple to my oil catch can.
thanks
jeff
Old Mar 17, 2007 | 08:50 AM
j spec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geoffroy &raquo;</TD></TR><TR><TD CLASS="quote">ok, i did some more research and i know how to fix it up. i will unscrew the plug that is on the right of my oil filter and get the plug off a 97 prelude. this plug has a nipple on it so i will be able to connect a line from this nipple to my oil catch can.
thanks
jeff</TD></TR></TABLE>
Very interesting i was planning on searching for an aeroquip fitting for this. Do you happen to know how large the nipple is? pics would be great.
Old Mar 17, 2007 | 09:34 AM
geoffroy's Avatar
Default Re: ls vtec question (j spec)
here is the link to the forum i found the info...
hope it helps
jeff
Old Mar 19, 2007 | 08:45 AM
geoffroy's Avatar
http://www.superhonda.com/foru...78671
Nisif
Sep 16, 2014 06:25 AM
Dunc
Aug 2, 2007 08:18 PM
fobile missile
Jun 15, 2006 02:19 AM
master honda tech
Dec 29, 2005 11:14 PM
drumking15
May 14, 2003 10:06 AM
