Cable LSD in my b16
Old Mar 16, 2007 | 08:23 AM
eviled's Avatar
Default Cable LSD in my b16
What LSD is everyone running in their Y1 and Y2 b16 trannys??
I have searched, and yes found lots of topics, but not the answer
thanks
Old Mar 17, 2007 | 04:23 AM
eviled's Avatar
Default Re: Cable LSD in my b16 (eviled)
do obx make an lsd i can use in Y1 cable boxes ??
Old Mar 17, 2007 | 07:37 AM
Crx Jimmy's Avatar
I believe cusco and kaaz make them for the cable tranny's
Old Mar 17, 2007 | 08:22 AM
Deetz's Avatar
Crazy Honda Guy
Don't use OBX, go with a Quaiffe
eviled's Avatar
Default Re: Cable LSD in my b16 (Crx Jimmy)
as do quaife, but all of those are very expensive.
anyone know of OBX does one that will fit ?
Old Mar 17, 2007 | 08:37 AM
GoFastTshirts.com's Avatar
OBX=Garbage if you have any sorta power , not trying to rain on your parade but it sux picking parts outta your tranny
Old Mar 18, 2007 | 01:25 PM
eviled's Avatar
Default Re: (GoFastTshirts.com)
plenty of people are using them in high hp turbo cars
i will have a low torque setup not exceed 200whp
Old Mar 18, 2007 | 03:45 PM
Garage 808 Hatch's Avatar
weld it
Old Mar 19, 2007 | 02:32 AM
eviled's Avatar
Default Re: (Garage 808 Hatch)
the UK scene has a lot more emphasis on going round corners than the US!
bump for OBX LSD
Old Mar 19, 2007 | 12:52 PM
EF_LSVtec's Avatar
Default Re: (eviled)
Quaife
Old Mar 19, 2007 | 02:00 PM
Fobtions's Avatar
u can use the obx in there but it depends on if u can transfer the ring gear off of your originall diff.
use the 90-up integra one/
Old Mar 19, 2007 | 02:07 PM
eviled's Avatar
Default Re: Cable LSD in my b16 (Fobtions)
is that the LS one ?
someone much have an OBX diff in an SiR
Old Mar 19, 2007 | 02:42 PM
racin_jayson's Avatar
Do you actually want experienced advice or are you just looking for someone to tell you that the obx lsd is good?
If you have already decided you want an obx lsd then buy one
Old Mar 20, 2007 | 03:33 PM
eviled's Avatar
Default Re: (racin_jayson)
i want the OBX one, but dont know which will fit and want experience with having one fitted in a y1/2 so I definately knwo it will fit
Old Mar 20, 2007 | 05:17 PM
Deetz's Avatar
Crazy Honda Guy
Your crazy if you want one
https://honda-tech.com/zerothread?id=1491127
https://honda-tech.com/zerothread?id=1485061
https://honda-tech.com/zerothread?id=1249085
https://honda-tech.com/zerothread?id=1206925
88 EF Hatch
15
Jan 3, 2009 09:18 AM
rkrone
Sep 21, 2007 08:18 PM
all_motoref9
Apr 5, 2004 08:04 AM
b204thgen
Jun 8, 2003 01:54 PM
cornholioEK
Sep 30, 2002 06:46 PM
