Drag Manifold + 57 trim = no fit?!?!?!?
Old Mar 15, 2007 | 07:39 PM
civicb18Tkid's Avatar
Default Drag Manifold + 57 trim = no fit?!?!?!?
i got a b18b and decided to upgrade to a t03t04e 57 trim and it is rubbing a little on the block.... i have a drag manifold
should i shave the block alittle? new manifold? lil help would be cool
thanks all
Old Mar 15, 2007 | 07:46 PM
eggie75's Avatar
Default Re: Drag Manifold + 57 trim = no fit?!?!?!? (civicb18Tkid)
just shave the block.
Old Mar 15, 2007 | 08:27 PM
95dc2teg's Avatar
Default Re: Drag Manifold + 57 trim = no fit?!?!?!? (eggie75)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eggie75 &raquo;</TD></TR><TR><TD CLASS="quote">just shave the block.</TD></TR></TABLE>
Old Mar 15, 2007 | 08:49 PM
Blind-Fashion's Avatar
Just shave the block, as long as its rubbing on one of the ribbs you are just fine.
Old Mar 16, 2007 | 07:38 AM
hybrid_KJ's Avatar
4 bolt or 5 bolt turbine housing?
Old Mar 16, 2007 | 08:04 AM
alltech_hybrid's Avatar
Default Re: Drag Manifold + 57 trim = no fit?!?!?!? (hybrid_KJ)
yup you gotta shave or cut a chunk of the block away so it fits..
Old Mar 16, 2007 | 08:18 AM
Pnoyej6's Avatar
* B A N N E D *
Default Re: Drag Manifold + 57 trim = no fit?!?!?!? (alltech_hybrid)
my drag turbo fits 57 trim on my lsvtec setup
Old Mar 16, 2007 | 09:26 AM
mike1114's Avatar
Default Re: Drag Manifold + 57 trim = no fit?!?!?!? (PnoyLSV-T)
most drag mani's are designed around a 5-bolt exhaust turbo, I believe.
A 4-bolt exhaust turbo will not work as they are angled differently from the centerline, therfore, it angles the turbo wrong.
I found this out the hard way too, I ended up selling the drag mani and getting a max-rev as this is one that is designed around a 4-bolt exhaust turbo.
Old Mar 16, 2007 | 10:49 AM
thanks everyone thats what i was thinkin.... debating weather i want to get a tubular manifold tho?? any difference in power?
Old Mar 16, 2007 | 11:13 AM
katoeh2o's Avatar
Default Re: (civicb18Tkid)
If you got to the full race web site they have dyno results that show a 40hp increse by change from a log mani to ramhorn.
Bictorious
Feb 29, 2004 06:17 PM
Muckman
Jan 16, 2004 09:31 AM
chris@cfranklins
Jan 1, 2003 04:35 PM
DRAGLS
Oct 14, 2002 06:30 PM
philo
Jul 20, 2002 06:40 AM
