Crvtec turbo...
Old Mar 15, 2007 | 07:00 PM
Boostedb20EH2's Avatar
Default Crvtec turbo...
Okay as im nearing the process of slapping this all together. I can run the oil line to my head from my turbo with the right fitting instead of tapping the block, correct? Searched..not alot turbo set ups with these motors.
Old Mar 15, 2007 | 07:19 PM
Default Re: Crvtec turbo... (Boostedb20EH2)
Bump for some help..
Old Mar 16, 2007 | 07:01 AM
Bump i think there was some confusion.. Im not tapping the block.. I would be using to GE fitting...but would rather put a fitting on my oil line to turbo if possible.
Old Mar 16, 2007 | 07:03 AM
2redstars's Avatar
your still confusing. turboing this motor is the same as any lsvtec. or any turbo car. except you need an additinal oil line to feed the head as with any ls/crv vtec motor
Old Mar 16, 2007 | 07:04 AM
2redstars's Avatar
use two seperate lines, one to feed the turbo, one to feed the head,.
Old Mar 16, 2007 | 07:10 AM
Default Re: (2redstars)
Ok this is what im saying. I have a oil line to the turbo.. I want to put on a fitting on that line so that i can split it and in to 2 and run one to the turbo and one to the head.
Such as..
I <---to head
Oil line from block.. I
I
-----------------------------------------------------------fitting.-------- <--to turbo O
Sorry for the text drawing
Old Mar 16, 2007 | 07:11 AM
Default Re: (Boostedb20EH2)
Didnt work anyways,i will draw one on paint when i get home.
Old Mar 16, 2007 | 07:13 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2redstars &raquo;</TD></TR><TR><TD CLASS="quote">use two seperate lines, one to feed the turbo, one to feed the head,.</TD></TR></TABLE>
I will be using one for each, i just want to branch the one for the head off the one from the turbo.
Old Mar 16, 2007 | 07:34 AM
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostedb20EH2 &raquo;</TD></TR><TR><TD CLASS="quote">
I will be using one for each, i just want to branch the one for the head off the one from the turbo.</TD></TR></TABLE>
And he just told you NOT to. That's a great way to starve your head for oil and ruin your motor.
Old Mar 16, 2007 | 12:50 PM
Default Re: (boosted92)
Umm..alright,I wanted to know something so i asked a question. I know people have more than likely tried it..so im kind of looking for someone to come out and say " I tried it,wasnt working out so i switched it". Or "This is how im running my set up it works "
Old Mar 16, 2007 | 12:53 PM
Turbocivic94's Avatar
always run oil feed from block
Old Mar 16, 2007 | 01:02 PM
Default Re: (Turbocivic94)
Is there a cheaper fitting than the golden eagle one? My budget isnt liking 225 for a few fittings headgasket and oil line.
Boostinb20!
Mar 27, 2009 07:06 AM
AJxr
Dec 7, 2008 08:14 AM
roycivic92
Dec 15, 2007 06:58 PM
MIKES
Jun 25, 2004 09:41 PM
