no brake light***
Old Mar 15, 2007 | 05:41 PM
nguyen726's Avatar
Default no brake light***
1999 civic cx hatch
all three brake lights isnt working
i checked all the bulbs they all work when i turn on my car with my headlights and parking lights. but when i step on the brake...not a thing.
im thinking its a fuse. so if it is show me where and what fuse to change..
thanks
Old Mar 15, 2007 | 05:44 PM
Padawan's Avatar
Darth ModerVader
Default Re: no brake light*** (nguyen726)
There is a fuse diagram in your owner's manual and also on the inside of the fuse panel.
Old Mar 15, 2007 | 05:47 PM
EL Vap133's Avatar
Did you do any wiring lately?
Old Mar 15, 2007 | 06:16 PM
nguyen726's Avatar
no wiring done.
Old Mar 16, 2007 | 10:46 AM
nguyen726's Avatar
Default *******no brake light!!
1999 civic cx hatch
thanks.
Old Mar 16, 2007 | 10:47 AM
nguyen726's Avatar
change the fuse, still no brake lights
Old Mar 16, 2007 | 10:48 AM
nguyen726's Avatar
sensor from the brake pedal?
Old Mar 16, 2007 | 12:15 PM
Relic1's Avatar
you do know that the brake lights are a seperate part of the bulb than the park lights right?
headlights/parklights - low part of bulb
brake lights - high part of bulb
the brake lights fuse for a 99 hatch is in the under hood fuse box. 15amp (if your horn works that's not the problem)
Old Mar 16, 2007 | 01:06 PM
BubblegumTate's Avatar
Default Re: (Relic1)
There is a pin switch above your brake pedal that activates the lights when you press the pedal. If all three brake lights aren't working, you should check that the switch is working. They can go bad or come unmounted.
Old Mar 16, 2007 | 01:27 PM
ARMED's Avatar
id say the thing...that switch on the brake pedal...
that button probably got stuck...its suppose to come out when you step on the brakes..check it out...
Old Mar 16, 2007 | 02:24 PM
nguyen726's Avatar
yes i checked it. that lil button does come out
Old Mar 16, 2007 | 02:28 PM
ARMED's Avatar
that might be bad....or the wirings are loose...
or maybe disconnected....
play with it...the button...
have someone look at your tail light see if the light comes on....
the only thing i can tell you is..
if its not the fuse...the bulb...the wirings...
thats should be it...that switch...try and replace it..go to the junkyard and get one...
Old Mar 16, 2007 | 02:47 PM
nguyen726's Avatar
alright koo. thanks.
Old Mar 16, 2007 | 02:49 PM
philosofy1's Avatar
Default Re: (nguyen726)
the switch behind the brake pedal probably needs adjusting. i would adjust it first before going out and buying one.
Old Mar 16, 2007 | 08:22 PM
nguyen726's Avatar
oo ok...how do i adjust it?
Tommay
Jun 21, 2012 03:48 PM
benw27
Honda Civic (2006 - 2015)
Jun 28, 2010 10:16 AM
cpuff
Oct 23, 2006 12:33 PM
JDMSloLude
Jul 18, 2004 09:33 AM
B00ST2nR
Jul 12, 2004 04:57 PM
