Brake Lights aren't working
Old Jul 11, 2004 | 10:11 PM
B00ST2nR's Avatar
Default Brake Lights aren't working
I don't know what the damn problem is. I installed the stock GSR Spoiler back on today and re-wired the 2 wires from the Spoiler LED light. After that, I checked if the 3rd brake light was workin or not by pressing the brakes, but not only did the LED not work... the whole damn Brake lights weren't working.
Know what the problem might be? The tail lights are working... just not the brake lights when I press the brake in.
Old Jul 11, 2004 | 10:16 PM
Redline130's Avatar
Default Re: Brake Lights aren't working (B00ST2nR)
Did you check the fuse by chance? I had a similar problem, traced all the wiring from the tail lights back, turned out to be a burnt fuse.
Old Jul 11, 2004 | 10:17 PM
B00ST2nR's Avatar
Default Re: Brake Lights aren't working (Redline130)
I'm gonna check the fuse tomorrow when it's bright... but in the manual, there wasn't a specific fuse for Brake Lights. Only Liscence Plate light/Tail Light Fuse... and like I said before, the Tail Lights work and come on... just not the brake lights.
Which fuse was burnt out for you? #2?
Old Jul 11, 2004 | 10:25 PM
Redline130's Avatar
In my EF hatch (the car with the problem), the fuse was located in the engine compartment fuse box. I'm not sure what number that fuse was. It was a 20 amp I believe. But my tail lights worked also, but my brake lights wouldn't come on when I pressed the brake pedal. I didn't know there was a separate fuse for the brake lights.
Old Jul 11, 2004 | 10:28 PM
Quik Chris's Avatar
I'm pretty sure the stop lamps are the same fuse as the gauge cluster-- either that or the interior lights. Just get a flashlight and check them all.
Old Jul 12, 2004 | 05:35 AM
b00sted93Hatch's Avatar
Default Re: Brake Lights aren't working (Quik Chris)
My Brake lights were the same fuse and my horn. Kinda weird I think. It located under the hood. I think its called stop/horn. BTW it was a 94 integra.
Old Jul 12, 2004 | 07:39 AM
B00ST2nR's Avatar
Default Re: Brake Lights aren't working (allMotor93Hatch)
Thanks for all the help. I'm gonna check all the fuses once I get back from Work.
Old Jul 12, 2004 | 04:51 PM
Redline130's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allMotor93Hatch &raquo;</TD></TR><TR><TD CLASS="quote">My Brake lights were the same fuse and my horn. Kinda weird I think. It located under the hood. I think its called stop/horn. BTW it was a 94 integra.</TD></TR></TABLE>
Same here. Couldn't remember what it was labeled.
Old Jul 12, 2004 | 04:57 PM
B00ST2nR's Avatar
yep. You guys were right.
It was the Stop/Horn fuse under the hood. It's all fixed now. Thanks!
MR Rodgers
Jan 5, 2009 02:32 PM
cpuff
Oct 23, 2006 12:33 PM
.Grimace
Sep 15, 2005 11:23 PM
goshred025
Feb 13, 2005 04:35 PM
LeonZ
Jun 21, 2003 04:17 PM
