Thoughts on Tial V60?
Old Mar 15, 2007 | 04:54 PM
A2gt35r's Avatar
Default Thoughts on Tial V60?
I have a turbo K & have major boost creep with one 44mm gate & no room for a second. Of course Tial says the V60 is the remedy for that but I'd like to know from some of the people using larger gates.
@ 14psi the motor makes 500+ whp & wanted a dtreet tune @ or below for those few times I might take it on the street. I have a cut off @ 15psi. & never get to rev past 6500.
I will be running a race gas only tune which will allow for higher boost but still have to deal with getting off the line!
These #'s were on my 2.4 & now I'm going to be installing a 2.2 that revs much higher & want to utilize all of the revs!
Art, Tony or someone who has good advice please chime in.
Thanks.
Old Mar 15, 2007 | 05:34 PM
integra_gsr98's Avatar
Default Re: Thoughts on Tial V60? (A2gt35r)
What wastegate and turbo combination are you running? How is wastegate placement on the manifold?
Old Mar 15, 2007 | 11:02 PM
null.'s Avatar
Default Re: Thoughts on Tial V60? (integra_gsr98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra_gsr98 &raquo;</TD></TR><TR><TD CLASS="quote">What wastegate and turbo combination are you running? How is wastegate placement on the manifold?</TD></TR></TABLE>
the key to creep
Old Mar 15, 2007 | 11:13 PM
Tex Blackwell's Avatar
Default Re: Thoughts on Tial V60? (null.)
We are using the 60MM wastegate on the race car without any spiking problems, placement of the wastegate is an important part though. the 60mm works perfect.
Old Mar 15, 2007 | 11:18 PM
1FSTHATCH's Avatar
Thats the main question on how the wastegates mounted to the manifold..I had to modify mine with just a 40mm gate cause it did the same thing..Now, it works fine..What size turbo and manifold are you using??
Old Mar 16, 2007 | 12:50 PM
A2gt35r's Avatar
This is what I understand. I have a sidewinder that has a 44mm gate positioned right before the flange facing up & bends 90 degrees.
Turbo is a T3 gt35r w/ 106 hot side.
Problem is there isn't any more room to go a different direction, but I could go a little bigger (v60).
Thanks for any good advice.
Old Mar 16, 2007 | 12:52 PM
A2gt35r's Avatar
Default Re: Thoughts on Tial V60? (Tex Blackwell)
Tex Blackwell, what is your setup & how low is your psi. out of the hole?
Old Mar 16, 2007 | 02:13 PM
We are taking off at 10psi every time, no issues.
Old Mar 16, 2007 | 02:42 PM
ls/vtec Garett 42R 1.44turbine
CP Pistons 9:1 compression,
Cometic .036 gasket
CNC Performance GSR cylinder head
Edelbrock Victor X intake manifold
Ferrea Valvetrain
water/air intercooled
AEM EMS 1060
1600cc injectors
quarter master carbon twin disk clutch with hydraulic throw out bearing
Drive Shaft Shop stage 5.6 axles with their halfshaft
Torco 116 octane gasoline
Old Mar 17, 2007 | 02:50 AM
A2gt35r's Avatar
Thanks Tex. It looks like I'm going to go with the V60 & hope that the position will be suffciant seeing how it's all I have for room!
Old Mar 18, 2007 | 04:55 AM
DaveF's Avatar
tex, how fast has that car been? i seen you got disqualified last weekend for running too fast without a license?
Old Mar 19, 2007 | 10:04 AM
Default Re: Thoughts on Tial V60? (dturbocivic)
HAHA yes, we did all of our NHRA license passes at Phoenix, AZ we qualified with a 10.22 so we wouldnt break out. The rest of the day was for NHRA license. We went 9.5@152 on 26psi, we will be testing before Atco and we'll see how we do. I have my NHRA license now!
Old Mar 19, 2007 | 10:12 AM
DaveF's Avatar
good to hear.
hope to see you soon
Old Mar 19, 2007 | 12:03 PM
hybridEj6's Avatar
Even exhaust pulses hitting the diaphram in the wastegate is crucial for relieble boost control. A well designed manifold will have this theory implemented into it's design.
Old Mar 19, 2007 | 12:05 PM
hybridEj6's Avatar
Default Re: Thoughts on Tial V60? (hybridEj6)
got any pictures of the set up?
Old Mar 19, 2007 | 03:14 PM
boosted92's Avatar
one warning, the tial 60mm gates are gigantic
Old Mar 19, 2007 | 05:01 PM
A2gt35r's Avatar
boosted92 can you get us a pic with a tape next to it, or just give height dimensions & I also couldn't find the diameter of the in/outlet.
Old Mar 19, 2007 | 07:06 PM
boosted92's Avatar
Default Re: (A2gt35r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A2gt35r &raquo;</TD></TR><TR><TD CLASS="quote">boosted92 can you get us a pic with a tape next to it, or just give height dimensions & I also couldn't find the diameter of the in/outlet.</TD></TR></TABLE>
That's actually not mine, just a pic I found on the net, but I have two on my car now and I can take some measurements for you tomorrow
Old Mar 19, 2007 | 07:34 PM
jdm94eg's Avatar
Default Re: (boosted92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote">
That's actually not mine, just a pic I found on the net, but I have two on my car now and I can take some measurements for you tomorrow </TD></TR></TABLE>
damn two that prolly looks insane lol put up a picture of it
spoolin turbo s
Nov 4, 2008 05:59 PM
Quickgti1.8t
May 13, 2006 10:28 AM
16vt
May 29, 2005 10:55 AM
turboedc2
May 20, 2005 12:57 PM
V-SPEC 1
Apr 29, 2004 07:43 AM
