Brake pad retainer clips keep snapping in half (poopy camera phone pic FTL)
My car: 93 civic dx hatch w/ 95 integra rs front spindle, trailing arm, 40/40 p.valve. Stock civic brake booster, 13/16 master cylinder. Earl's stainless brake lines.
I've had to replace 7 clips so far (2 clips per caliper) in only a few months. They keep snapping at the weakest/thinnest part on them (the bottom clip). I don't even use my brakes much at all. What could be causing this? They cost $5 a piece at the stealership and it is annoying having to replace them every few weeks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EH2palmyblueSIR2 »</TD></TR><TR><TD CLASS="quote">anyone?</TD></TR></TABLE>
Wrong pads? I'd have to see it in person to really get an idea. Why are you rolling around with larger calipers then stock with a stupid 13/16 master cylidner? not smart. Get the 15/16 master cylinder on there and you will be amazed how well those brakes work.
I bought some Axxis ultimate pads for a rear disc swap. When I tried to fit them, they were so tight that I figured they would NEVER work properly, and would quickly destroy those clips. I had to bust out the grinding wheel, and grind down the tabs on the ends of each pad until they fit loose (like OEM Nissin) and slid smooth back & forth. Perhaps if you have aftermarket pads, your experiencing a similar problem that is wearing out your hardware...
The pads should slide in & out very easily. My 03 Element has quite a bit of play in the pads. So much that each time I switch direction forward/reverse, I you can hear all four pads shift in their seats when I press the brake...
Plus, lubing up the sliding surface of those clips with disc brake grease is a good idea...
Hybrid93eg: I plan on getting the 15/16th mc from a 91 civic ex in the near future. The one that is in there seems to be fine so I didn't want to replace it if it was in good mechanical condition.
94eg!: Yes, they are aftermarket autozone pads. They seem to fit pretty nicely. I got them with the spindles. I will try to lube where the pad comes in contact with the clip.
My pads have one metal tab on each pair. I put the two pads with the metal tabs on the inside of the mounting bracket(closest to the engine bay). What is the deal with the metal tab? Is this correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EH2palmyblueSIR2 »</TD></TR><TR><TD CLASS="quote">My pads have one metal tab on each pair. I put the two pads with the metal tabs on the inside of the mounting bracket(closest to the engine bay). What is the deal with the metal tab? Is this correct?</TD></TR></TABLE>
Yes the pad with metal tab goes on the engine-side of the brake assembly. This is a wear indicator. Basically once your pads get worn down, that tab comes into contact with the rotors surface. As you can imagine, it makes a horrendous noise when the brake pedal is pressed. It gets the average person to bring their car in for an inspection before the brake pads are totally gone...
DO/\/\O
20
Sep 10, 2011 08:22 PM
