H22 EG's I need your help
Old Mar 15, 2007 | 01:04 PM
Honda_Fanatic's Avatar
Default H22 EG's I need your help
I completed my swap, but am haveing some axle vibration on occasion.
What setup is the most reliable?
Half shaft? Pass? Drivers?
I don't plan to slam my car but would like to lower it an inch or so at least.
Old Mar 15, 2007 | 01:54 PM
poison's Avatar
Default Re: H22 EG's I need your help (Honda_Fanatic)
What mounts & axles are you using?
Old Mar 15, 2007 | 03:01 PM
Default Re: H22 EG's I need your help (poison)
Hasport mounts
H22a Midshaft/ Halfshaft
Teg outer lude inner passenger and drivers side
Old Mar 15, 2007 | 06:23 PM
bump it up
Old Mar 15, 2007 | 08:01 PM
finally found a good link
https://honda-tech.com/zerothread?id=434668
Old Mar 15, 2007 | 08:28 PM
envee's Avatar
answered your own question it seems
Old Mar 15, 2007 | 08:35 PM
Default Re: H22 EG's I need your help (envee)
after a full day of searching I found a thread with all the info I needed.
So yea - once I get the new parts hopefully it will be problem solved.
Old Mar 15, 2007 | 08:48 PM
envee's Avatar
souds good. gl.
Old Mar 15, 2007 | 08:51 PM
thanks
Old Mar 15, 2007 | 08:52 PM
envee's Avatar
np
Old Mar 15, 2007 | 09:02 PM
rigles1's Avatar
GATOR AXLES!!!
Old Mar 15, 2007 | 09:25 PM
Hazen85's Avatar
Default Re: H22 EG's I need your help (rigles1)
what lowering kit r u planning to put on the EG
Old Mar 15, 2007 | 10:11 PM
Default Re: H22 EG's I need your help (Hazen85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rigles1 &raquo;</TD></TR><TR><TD CLASS="quote">GATOR AXLES!!!</TD></TR></TABLE>
yea right - I ain't no baller
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hazen85 &raquo;</TD></TR><TR><TD CLASS="quote">what lowering kit r u planning to put on the EG </TD></TR></TABLE>
I own a DC - but I am either going TEIN SS - OMNI - or D2
Not for sure yet - depends on cash flow.
Old Mar 15, 2007 | 10:30 PM
ke98248's Avatar
post up pix when ur done!
Old Mar 16, 2007 | 03:22 AM
https://honda-tech.com/zerothread?id=1916197
Old Mar 16, 2007 | 07:07 AM
civich22aturbo's Avatar
I have some Driveshaftshop stage 2 axles on my turbo H22 in my EK and they are awesome.I'm running some 18" rim with 2 inch drop and I've haven't felt any vibration.They don't go for cheap but if you want something reliable that's the way to go!!!!
HATCH22A
Jan 5, 2010 06:54 AM
cycopath
Apr 22, 2008 10:05 AM
The Destroyer
Apr 1, 2008 08:07 PM
bullmannn
Nov 16, 2007 08:42 PM
djroven
Apr 12, 2007 08:44 AM
