Help! H22 EG Avid mounts!!!!!!!
* B A N N E D *
Hey I gotr may h22 in my eg with avid moutns everything is awesome expect one thing
For some reason my dirver side axle is binding up It looks like it is sitting at a 35 degree angle,. We tried shimming the tranny mount with washers and it helped alittle but not all the way.
I am using hasport axles, Can someone please help like ASAP!!
* B A N N E D *
Re: (irollerblade)
Like I said, It's just permanet(sp?) binding, can't drive it as a result.
If I just get the accord intermeditate shaft with intergra axle will i be fine?
Re: (cycopath)
same problem here.... i had avids with my h22 eg and i had hasport axles... i ended up snapping my drivers side axle becasue of the same problem
the hasport axles are made to work with the hasport mounts and only those mounts...
what i ended up doing was using the accord half shaft with integra axles,, they worked perfect for me... you have to make sure you dont have alot of negative camber also or the passenger axle will pull out a lil on ya sometimes...
but when its all said an done i would invest in hasport
With the Avid mounts, you can use the an OEM axle combo. As long as you have a 90-93 Accord half shaft, you can use 90-93 integra axles no problem!
vy3tnamezz
08-31-2007 05:39 AM
