Weird Low Idle Problem
Old Mar 15, 2007 | 11:34 AM
zach1288's Avatar
Default Weird Low Idle Problem
The car will idle fine if the headlights are on and the fan blowing cold or hot air in the car. It will idle alittle below 1k. But if i turn the "interior" fan off or the headlights the car will idle low like around 400 or lower and feel like its going to stall? What should i check?
Old Mar 15, 2007 | 01:18 PM
zach1288's Avatar
Anyone?
Old Mar 15, 2007 | 02:58 PM
hall97civic's Avatar
Default Re: (zach1288)
first off, what kind, model, ect of car, and secondly a 1.6 idles 350-500rpm stock. When accesories are on, it'll kick it up to about 800
later
Old Mar 15, 2007 | 05:21 PM
zach1288's Avatar
Default Re: (hall97civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hall97civic &raquo;</TD></TR><TR><TD CLASS="quote">first off, what kind, model, ect of car, and secondly a 1.6 idles 350-500rpm stock. When accesories are on, it'll kick it up to about 800
later</TD></TR></TABLE>
Its in my signature man
Old Mar 15, 2007 | 05:34 PM
robble36's Avatar
well, put it this way many people wish their car could idle as low as your's does hahaha
Old Mar 15, 2007 | 05:37 PM
dohcdelsol's Avatar
d16z6 motor idles 650 + - 50 rpms.
check for vaccum leaks. clean out ur EACV and FITV.
Old Mar 15, 2007 | 06:48 PM
zach1288's Avatar
Default Re: (dohcdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol &raquo;</TD></TR><TR><TD CLASS="quote">
check for vaccum leaks. clean out ur EACV and FITV. </TD></TR></TABLE>
What should a b16a2 idle at?
Old Mar 16, 2007 | 04:55 PM
zach1288's Avatar
Bump
Old Mar 18, 2007 | 05:47 AM
zach1288's Avatar
What is the b16a2 suppose to idle at??
Old Mar 19, 2007 | 02:59 PM
zach1288's Avatar
Old Mar 19, 2007 | 04:29 PM
borenshoratius's Avatar
750-800
Old Mar 26, 2007 | 01:54 PM
zach1288's Avatar
Default Re: (borenshoratius)
bump
Old Mar 26, 2007 | 02:06 PM
pdiggitydogg's Avatar
christ...
adjust your idle screw...its probably set too low (high enough when excess current is drawn but too low when those things are off)
Old Mar 26, 2007 | 02:18 PM
zach1288's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">christ...
adjust your idle screw...its probably set too low (high enough when excess current is drawn but too low when those things are off)</TD></TR></TABLE>
That screw only adjusts the idle when the engine is cold. The IACV controls the idle after the car is warmed up..
Old Mar 26, 2007 | 03:56 PM
try it...
adidasklip
Sep 5, 2007 05:26 PM
93JDMB18C
Nov 2, 2006 02:03 PM
clutcher
Apr 6, 2005 08:04 PM
Shaguar47
Dec 12, 2004 11:22 AM
Br1anPham
Feb 2, 2004 05:29 PM
