OBD1 to OBD2 injector conversion
Old Mar 14, 2007 | 09:01 PM
nicko360's Avatar
* B A N N E D *
Default OBD1 to OBD2 injector conversion
Hey
Ive got a d16z6 OBD1 in my 1994 civic cx. I have a set of OBD2 DSM injecotrs that I would like to install (they dont fit OBD1 injector clips)
I went to this Honda place, and went through a bunch of harnesses until I found one with the clips that fit. The harness was labeled 93 accords? but the injectors fit the clips
So I got the clips and the injectors im just wondering which wires on the clips go to the ones on the harness?
i searched but with not much luck
Is it possible to do this conversion?
Old Mar 15, 2007 | 08:31 AM
nicko360's Avatar
* B A N N E D *
Default Re: OBD1 to OBD2 injector conversion (nicko360)
bump
Old Mar 15, 2007 | 08:40 AM
yee SERIOUS's Avatar
it doesn't matter. the two wires can go to any two. they are just used to send a signal to the injector to open and close.
Old Mar 15, 2007 | 10:08 AM
dad0c402's Avatar
I turned my obd2 to obd1 clips to run w/ a donor engine for the mean time. I did match the black wire with a color/back stripe ff the honda harness, I could see how kidsafe is correct b/c the motor started perfect after the first try.
Old Mar 15, 2007 | 12:22 PM
nicko360's Avatar
* B A N N E D *
Default Re: OBD1 to OBD2 injector conversion (dad0c402)
so it doesn't matter which wire goes to which?
also I need help wiring in the resistor box for the DSM injecotrs
thanks
Old Mar 15, 2007 | 12:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicko360 &raquo;</TD></TR><TR><TD CLASS="quote">so it doesn't matter which wire goes to which?
thanks</TD></TR></TABLE>
no it doesn't matter. i've had to convert my obd2 clips to obd1. as long as they're wired up and have a goood connection, it is ok. try to get them soldered if you can.
here is a write up on resistor boxes by ladysman:
https://honda-tech.com/zerothread?id=517274
Old Mar 15, 2007 | 01:33 PM
nicko360's Avatar
* B A N N E D *
Default Re: OBD1 to OBD2 injector conversion (kidsafe yee)
thanks, im gonna go try it now
Old May 21, 2007 | 05:21 PM
tehpr3chr's Avatar
would the obd2 injectors work in the obd1 engine? i have my old engine w/ injectors still, and could just swap those out if it'd work...
Old May 21, 2007 | 06:22 PM
dannis.'s Avatar
Default Re: OBD1 to OBD2 injector conversion (tehpr3chr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tehpr3chr &raquo;</TD></TR><TR><TD CLASS="quote">would the obd2 injectors work in the obd1 engine? i have my old engine w/ injectors still, and could just swap those out if it'd work...</TD></TR></TABLE>
did you even read this thread or are you just, dee dee dee!
Old May 30, 2007 | 10:04 AM
lucky4586's Avatar
Default Re: OBD1 to OBD2 injector conversion (dannis.)
its only dee dee FYI lol
Old May 30, 2007 | 11:51 AM
big-cat's Avatar
yes, i needed to find that out as well......stress relieved.
Old May 30, 2007 | 11:54 AM
fmrprojects's Avatar
Default Re: (big-cat)
you can put the clips on just shave the injector on the inside. there is a little part in the middle that the obd-1 injector doesnt have. just get a blade and cut it off. the obd-1 clip should snap right on. im using obd-2 440 injstors with a obd-1 wiring harness. all the clips fit tight and never had a problem
jayswizz
Feb 15, 2014 04:47 AM
Maleek
May 17, 2012 08:47 PM
jewpont
Jul 11, 2009 01:24 PM
RBNightMare
Feb 13, 2007 11:50 AM
RACEPAK
Jul 19, 2005 09:51 AM
