finding T.D.C on distributor
Old Mar 14, 2007 | 06:15 PM
jdm Ef-9's Avatar
Default finding T.D.C on distributor
i put a new distributor on the car but forgot to see where the rotor was sitting before i switched them...... i take it that 1 full turn to the input shaft is 90 degrees for the rotor......
also, can the shaft go onto the cam at 180 degrees, or is it only 360....
thanks
matt
Old Mar 14, 2007 | 06:30 PM
sporkcrx's Avatar
Default Re: finding T.D.C on distributor (jdm Ef-9)
It can go in correctly, or 180 degrees off. Put the motor at tdc, the rotor facing the #1 contact and you're set.
crxmobber's Avatar
dont worry, your cool. the notch on the end of the cam is offset so it can only go on 1 way.....
Old Mar 14, 2007 | 06:33 PM
Slurp56's Avatar
The cam slot is off center. Look at the end of the distributor that goes into the head and make it lines up with the slot in the cam. It can go in 180 out, but you'll have to force it.
Old Mar 14, 2007 | 06:40 PM
jdm Ef-9's Avatar
Default Re: finding T.D.C on distributor (Slurp56)
cool. because i had no spark.... replaced the distributor but now still dosent fire over..... battery is brandnew, fuel pressure is fine...and have no gasket leaks. i got air, fuel, and spark....the only other thing i can think of is the ecu..... im not a dumb wanabe mechanic.....i wrench on diesels allday long. so please dont think of be as another dumb kid..... but the best need a 2nd opinon somethimes...
thanks
matt
Old Mar 14, 2007 | 06:46 PM
essex's Avatar
Is there any codes on the ecu?
Old Mar 14, 2007 | 06:56 PM
jdm Ef-9's Avatar
Default Re: finding T.D.C on distributor (essex)
got ya stumped.....huuu, ya are the honda gods.....lol...try me, i checked everything.....but the ecu
Old Mar 14, 2007 | 09:17 PM
teewhy55's Avatar
make sure the plug wire order to the distributor is correct. I think the rotor can go on 2 ways, try flipping it since u didnt check the old one. maybe the refurbished distributor u got is junk? sometimes the battery dies after cranking on it for too long, make sure its charged. make sure kill switch or anything isn't on. im running out of ideas, good luck.
Deadpool98
Engine Machining & Assembly
Apr 1, 2019 07:40 PM
RiPe14yoU
May 16, 2017 02:44 PM
sr20paisa
18
Nov 14, 2015 03:40 PM
Mentat Ghola
Oct 21, 2004 04:36 PM
austrian type-R
Jul 25, 2002 03:41 AM
