Removing Broken Stud
Old Mar 14, 2007 | 10:41 AM
dr_latino999's Avatar
Default Removing Broken Stud
So I'm removing a broken valve cover stud in my Z6 head, and its about 3 mm into the head. I'm trying to drill a pilot hole for my easy out with a 1/8" Titanium Drill Bit, but it went down a fraction of a mm and has not made any more progress. Any ideas for removing this stud, or at least getting a hole into the stud?
Old Mar 14, 2007 | 10:44 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: Removing Broken Stud (dr_latino999)
OK, dumb question but it's happened to me before on a brain-fart riddled day..... you do have the drill going forward correct?
Old Mar 14, 2007 | 10:46 AM
Default Re: Removing Broken Stud (wiZCo)
Yes the drill is going the right way lol, I made a maybe half a mm hole and that was the end of that.
Old Mar 14, 2007 | 10:49 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Yes the drill is going the right way lol, I made a maybe half a mm hole and that was the end of that.</TD></TR></TABLE>
LOL, just had to throw it out there.... using a Titanium drill bit and not making progress? Hmmmm.... I'd say you'd have problems if the bit was dull, that's all I can really think of. Although in my experience sometimes you get studs/bolts that just seem to not cooperate no matter what you do. As a last resort you may just want to try drilling it out one size over then re-tepping and threading.
Old Mar 14, 2007 | 11:00 AM
Well it's a fresh drill bit, just bought it this morning. But since I'm getting annoyed, I've switched weapons to the Drill Out Micro Power Extractors from Craftsman. Let's see if a left hand rotating bit helps.
Old Mar 14, 2007 | 11:57 AM
Well in all likely hood, the cylinder head is now trashed, when hitting the pilot hole we manage to get with the eazy-out the cam cap cracked, and part of it is missing and we think it fell into the motor somewhere.
ryanangelo212
Oct 27, 2010 08:02 PM
B18C_EJ8
Oct 29, 2007 04:33 PM
SuperSi
Jan 29, 2006 06:54 PM
ek9800
Nov 25, 2004 08:31 PM
Dusty.
Apr 8, 2004 11:47 PM
