Slow boost build below 4,000 RPM on Accord SOHC
Old Mar 13, 2007 | 07:59 PM
teamlegacy's Avatar
Default Slow boost build below 4,000 RPM on Accord SOHC
Hey all, I seem to be having a issue with boost building slow during the beginning of shifting into 3rd and 4th, 5th usually as well but as soon as I get to 4,000RPM and up, it holds 10psi like a dream.
Here's the setup:
Mild-built F22A6 SOHC
stock bottom end
EVOIII Big 16g turbo
DSM modified manifold with Tial 38mm ext wastegate
2.5" o2 housing with 3" side exit exhaust
2.5" charge piping hot/cold
P75 SOHC_MShue tuned on Crome
The car is smokin' fast and runs great. But if I redline third and shift to fourth, it's boggy feeling until 4,000RPM hits. Anyone run into a similar issue, obviously not on the same setup since no one boosts Accords haha
I'm really looking for a reason why or anything to help boost build quicker...or at least smoother and more exponentially.
[Oh, Off-Topic, I recommend everyone updating to the new Firefox, I can spell check any topic/post box on any forum or website...it's awesome!]
Colin
Old Mar 16, 2007 | 06:41 AM
slowturbocx's Avatar
Default Re: Slow boost build below 4,000 RPM on Accord SOHC (teamlegacy)
you prob. have an exhaust leak, but those turbos have a pretty big exhaust wheel on them so they are a little laggy on honda motors.
Old Mar 16, 2007 | 09:26 AM
raceACCORDingly's Avatar
isnt the dsm manifold casted and kinda hard to weld? you sure the custom external 38mm gate port isnt leaking?
Old Mar 16, 2007 | 02:06 PM
HiProfile's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamlegacy &raquo;</TD></TR><TR><TD CLASS="quote">
Colin</TD></TR></TABLE>
lol, HT already has a SC feature, and SCing someone else's work is for spelling *****.
I would ask mshue if he messed with the gear ign retard at all. That and look for any exhaust and boost leaks. Use the pvc-cap method and pressurize it from the TB coupler to the turbo coupler.
j-bird20
Jun 15, 2010 01:17 PM
FMIDRC Racer
May 14, 2006 12:28 AM
slammedcoupe
Jun 19, 2005 12:17 PM
Ricen civic
12
Nov 18, 2004 07:49 PM
tysf
Aug 23, 2002 10:19 AM
