Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Remote Start
Old Mar 13, 2007 | 01:01 PM
K20Z3Si's Avatar
Default Remote Start
I was just wondering since i have no clue about alarm systems, how a remote start can be installed on a car with a clutch. I assume that there is a way for the remote start to bypass the usual system of starting a car.
Old Mar 13, 2007 | 01:09 PM
Perfectionist's Avatar
Default Re: Remote Start (K20Z3Si)
The true remote start systems for manual trans vehicles make you place the trans in nuetral with the parking brake set, release the clutch pedal, and turn the ignition off, or some such other specific sequence or the remote start won't work. Some people have hacked in a system for auto trans vehicles and justify their work by swearing they will never leave the trans in gear, so they don't see any problem with that.
Overall, my opinion is remote start is just some woopie-doo gadget and is totaly unecessary, and I live in a very cold climate.
just my opinion.
Old Mar 13, 2007 | 01:12 PM
Hellzcivic's Avatar
Yes, they run a bypass. On mine it's a little funky. After I remote start, you have to insert the key and turn it to the run position before you do anything. If I get in the car and press the brake or clutch before I insert the key, the engine shuts off and the ignition becomes disabled. To re-enable the ingition, you have to press the "unlock" button a couple times on the remote. When I shut the car off, I have to have the car in neutral with no pedals depressed.
Also, you need to be sure you do not leave the car in gear when you park. If your shifter gets locked out it's easy to release.
Old Mar 13, 2007 | 01:15 PM
TRE_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20Z3Si &raquo;</TD></TR><TR><TD CLASS="quote">I was just wondering since i have no clue about alarm systems, how a remote start can be installed on a car with a clutch. I assume that there is a way for the remote start to bypass the usual system of starting a car. </TD></TR></TABLE>
Most shops will not install a remote start in a MT vehicle unless they have some sort of wavier releasing them of any sort of liablity. But yes they basically bypass the clutch switch. Other shops use something around the shifter so that if the car is in gear it will not start via the remote start.
I've had it on vehicles before and it can be nice but it is kinda unneccesary in most cases
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hellzcivic &raquo;</TD></TR><TR><TD CLASS="quote">After I remote start, you have to insert the key and turn it to the run position before you do anything. If I get in the car and press the brake or clutch before I insert the key, the engine shuts off and the ignition becomes disabled. </TD></TR></TABLE>
Mine was the same way... I beleive this is how pretty much all of them are setup
Old Mar 13, 2007 | 04:35 PM
K20Z3Si's Avatar
Default Re: Remote Start (TRE_)
Thanks for the info guys
Old Mar 13, 2007 | 04:44 PM
K20Z3Si's Avatar
Default Re: Remote Start (Perfectionist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist &raquo;</TD></TR><TR><TD CLASS="quote">
just my opinion.</TD></TR></TABLE>
It would still be nice to have, but the car does warm up very quickly in the morning.
Old Mar 13, 2007 | 05:53 PM
Rahxephon's Avatar
don't be lazy go out side and start it up like a man..
Old Mar 13, 2007 | 09:38 PM
S1NFUL RL1 619's Avatar
Default Re: Remote Start (Rahxephon)
authorized DEI installers are not allowed to install the remote starters on any MT vehicle, and if you own a DEI remote starter and you install it yourself (on your MT car) it voids your warranty.
and DEI remote starters have those security features ie, turning the ignition to the "on" position before pressing the brake or releasing the e-brake. it's the same thing as the hood pin, just another layer of security to deter theives.
the remote starter may not be neccessary for those who don't mind warming up their cars before taking off. but i know i loved using it on my DB7 when i still had it. that thing took forever to warm up. haha
neonoodle
Audio / Security / Video
34
May 29, 2008 09:14 AM
dumafu
Jun 5, 2007 12:49 PM
Jap_Spec_Imports
30
May 26, 2006 05:43 PM
colt45qb
12
Aug 12, 2004 03:24 PM
D15B_Turbo
Oct 8, 2002 10:03 PM
