Corner lights not working
Old Mar 12, 2007 | 12:42 PM
J9D6M's Avatar
Default HELP corner lights!
My headlights work fine, but my corner lights are not working. The turn signal lights in the bumper work and so do the ones in the rear, but from some reason the turn signals and running lights in the corner piece of the headlight are not working. I checked fuses and bulbs, cleaned the grounds, inspected the wires as best i could and couldnt find anything wrong. Has anyone had thsi similar problem or have anything I may have forgotten to check?
Modified by J9D6M at 2:02 PM 3/12/2007
Old Mar 12, 2007 | 01:24 PM
J9D6M's Avatar
Default Re: HELP corner lights! (J9D6M)
help!
Old Mar 12, 2007 | 03:03 PM
J9D6M's Avatar
bump
Old Mar 12, 2007 | 04:17 PM
J9D6M's Avatar
some1!
Old Mar 12, 2007 | 05:00 PM
grog's Avatar
check the relays ,use a multimeter to check for power.
theres info if you search on how to check various relays. but I think the headlights and blinkers might share a relay, and your lights do work.
have you done any wiring lately? you probley didnt but its always a good question to ask. did the lights work before? have you changed the wiring from the stock lighting, I have.
also the light switch on the steering colum is a part of the lights, you might try a search on the switch, I know its goes bad on some efs
Old Mar 12, 2007 | 05:41 PM
J9D6M's Avatar
Default Re: HELP corner lights! (grog)
I tried using a multimeter briefly today but the wires were so greased and shitted up, but anyway i didnt get anything to them.
If the relay is for both the headlights and turnsignals, then it isnt that beings the headlights work.
The lights never worked since i got the car. I did not do any wiring. That switch should have nothing to do with it beings the turn signals are engaging and working, just not inthose particular bulbs...Thanks for the insight tho
Old Mar 12, 2007 | 05:55 PM
J9D6M's Avatar
Does anyone have a wiring diagram that may help me? yes i've searched
Old Mar 12, 2007 | 06:03 PM
grog's Avatar
look in the ef FAQ's
Old Mar 13, 2007 | 08:15 AM
J9D6M's Avatar
heeellllpppp
Old Mar 13, 2007 | 09:21 AM
Fidanza ZC's Avatar
Mine are doin the same thing, they used to work and one day they just stopped workin, if u find out what the problem is plz tell me!
Old Mar 13, 2007 | 11:17 AM
rbwdriven's Avatar
have you checked the bulbs or changed them?
sometimes the bulb looks good to the eye due to the filament is still sitting next to each leg. Get a pack of replacement bulbs it will only cost $2.00 at the store that way you can say the bulbs are definitely no good.
Old Mar 14, 2007 | 09:13 AM
J9D6M's Avatar
Default Re: (rbwdriven)
I just replaced all four bulbs and still nothing...This is the only thing keeping me from FINALLY getting my car inspected and on teh road, please help!
rdemel
Honda Civic (2001 - 2005)
May 15, 2017 05:26 AM
red ej
Lighting
Jan 1, 2008 12:23 AM
skylinexr
May 8, 2007 02:30 PM
stupidwhitecat
Nov 5, 2005 04:26 AM
specbb6
May 27, 2005 01:03 PM
