Well, I threw a rod on Monday...
Old Mar 11, 2007 | 08:27 PM
EX-T's Avatar
Default Well, I threw a rod on Monday...
I had a boosted Y8 with a GReddy kit and I threw a rod on the interstate on Monday (wish I was looking at the boost gauge). This only gives me a reason to build one now.
I've got some Vitaras and H beams on the way and I have another Y8 at my work that was free and came out of a running car.
My questions is that will an OBD2a Y8 go into an OBD2b vehicle without any problems?
I know that to OBD2a Y8 has a crank angle positioning sensor that the OBD2b motor doesn't have. Is it OK to just remove the sensor?
Old Mar 11, 2007 | 08:29 PM
fmrprojects's Avatar
Default Re: Well, I threw a rod on Monday... (EX-T)
its the same block just with added sensors. yes you can use it
Luserkid's Avatar
Just use all your obd2b stuff.
Old Mar 13, 2007 | 08:07 PM
EX-T's Avatar
Default Re: Well, I threw a rod on Monday... (Luserkid)
I just remembered that I've have a Crome chipped P06-VTEC ecu that's going in it so I won't have to worry about a few of the sensors anyways...
Is it completely necessary to remove the crank to take the rods and pistons out?
AbitAvenger
Feb 22, 2012 12:35 PM
98EJ7Y8
Feb 6, 2012 03:53 PM
Dmonster
May 28, 2010 10:36 PM
thurmondauto
Jun 28, 2009 05:02 PM
mattie_96
Oct 8, 2006 06:18 PM
