need help asap
Old Mar 11, 2007 | 11:17 AM
frog169's Avatar
Default need help asap speedo/odom no workie :(
so i was driving i turned my head then looked back now my speedo isnt working as well as my odom. i checked my codes to see what its spitting out and its spitting out the code 17:VSS Sensor and code 41: Primary oxygen sensor heater as well as like knock sensor and tps but mainly worryed about the spedo and odom. help pls btw its a 92 civic w/b16
Modified by frog169 at 12:32 PM 3/11/2007
Old Mar 11, 2007 | 12:09 PM
MJ0LNIR's Avatar
Default Re: need help asap speedo/odom no workie :( (frog169)
ok... so check the vss
Old Mar 11, 2007 | 12:11 PM
Syndacate's Avatar
Default Re: need help asap speedo/odom no workie :( (dr92cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr92cx &raquo;</TD></TR><TR><TD CLASS="quote">ok... so check the vss</TD></TR></TABLE>
Yeah...
Buy a vehicle speed sensor.
If it's OBD-II buy one for a 99/00 Si, if it's OBD-I buy one for a OBD-I del sol w/ a B16a3.
Old Mar 11, 2007 | 02:59 PM
frog169's Avatar
Default Re: need help asap speedo/odom no workie :( (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">Yeah...
If it's OBD-II buy one for a 99/00 Si, if it's OBD-I buy one for a OBD-I del sol w/ a B16a3.</TD></TR></TABLE>
sorry im dumb how do i know if its obd 1 or obd 2 :X i took it off and a piece of it is broken and i have no clu what make/model car i need to buy it for. b16 is a obd-i isnt it?
Old Mar 11, 2007 | 03:02 PM
19992civichatch's Avatar
what year of the car did the engine come out of
Old Mar 11, 2007 | 03:05 PM
frog169's Avatar
Default Re: (19992civichatch)
prev owner never told me :-/ all i know is on top of it is a 3 prong connector
Old Mar 11, 2007 | 03:15 PM
can u get a picture, and has the head been changed casue i think not sure someone where on the head it will say the year
Old Mar 11, 2007 | 03:17 PM
frog169's Avatar
Default Re: (frog169)
i did a vin look up and it came out with
Year/Make/Model: 1997 ACURA INTEGRA LS
Body Style: HATCHBACK 2 DR
Engine Type: 1.8L L4 PFI DOHC 16V
Manufactured In: JAPAN
:-/ hope this helps?
Old Mar 11, 2007 | 03:19 PM
frog169's Avatar
what do u want me to take a pic of? ill try to take one right now
Old Mar 11, 2007 | 04:09 PM
prev owner never told me :-/ all i know is on top of it is a 3 prong connector------ u where taking about the vss right?
Old Mar 11, 2007 | 04:58 PM
frog169's Avatar
ya on top of the vss is a 3 prong connector the owner never told me what yr and what not it was from. or what yr/model car to get parts.
Old Mar 11, 2007 | 08:31 PM
frog169's Avatar
umm its a p72 ecu isnt that a Obd-i?
Old Mar 11, 2007 | 08:43 PM
fmrprojects's Avatar
it doesnt matter its all the same vss. you can use any vss sensor from any b series motor. ls, gsr, type r, b16 of any year
Old Mar 12, 2007 | 05:40 AM
frog169's Avatar
Default Re: (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">it doesnt matter its all the same vss. you can use any vss sensor from any b series motor. ls, gsr, type r, b16 of any year</TD></TR></TABLE>
is there a certain year? and there was like 2 types of vss so i was like humm which is why i started researching
Old Mar 12, 2007 | 11:32 AM
sql_civic's Avatar
Default Could be grounds
Check all your ground wires. I had problems with all of the sensors you mentioned and all I had to do was tighten down the ground cable on the thermostat housing.
Old Mar 12, 2007 | 06:41 PM
frog169's Avatar
Default Re: Could be grounds (sql_civic)
no we took off vss and part of the piece is broken.
cmsrally
12
Jan 25, 2006 08:34 AM
unknown0001
Feb 28, 2005 02:43 PM
GdmLaz
Dec 4, 2004 04:00 PM
ransack
Apr 7, 2004 03:57 PM
