Max bore for stock gsr sleeve?
Old Mar 10, 2007 | 04:24 PM
black99x's Avatar
Default Max bore for stock gsr sleeve?
I need to know if I can boost my motor... around 9.5:1 comp and 82mm bore with the stock pistons, rods and bore...
Old Mar 10, 2007 | 04:30 PM
Schister66's Avatar
Man U FTW
82mm on stock sleeves would make me uneasy
Old Mar 10, 2007 | 04:34 PM
BoostedEG6's Avatar
Default Re: (Schister66)
I wouldnt go over 81.5 on stock sleeves with boost
Old Mar 10, 2007 | 04:43 PM
A.E Motoring's Avatar
Default Re: (BoostedEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 &raquo;</TD></TR><TR><TD CLASS="quote">I wouldnt go over 81.5 on stock sleeves with boost</TD></TR></TABLE>
Old Mar 10, 2007 | 06:33 PM
black99x's Avatar
Default Re: (Dual Cam Racing)
Thanks guys- And that sucks.... I think around 12psi would be okay but no chance to tune 20+ and race gas..
Old Mar 10, 2007 | 07:45 PM
doood's Avatar
been there done that
Default Re: (black99x)
82mm is pushing it for NA. wouldnt go that big with boost.
did you say stock pistons with 82mm bore?
Old Mar 11, 2007 | 08:16 AM
black99x's Avatar
Default Re: (doood)
Stock as in not forged.... oem style i meant.
Old Mar 11, 2007 | 09:44 AM
b18sihatch's Avatar
wouldnt go that far, you would definitly be looking to crack a sleeve\s
Old Mar 11, 2007 | 10:09 AM
Bjorn20's Avatar
Default Re: (b18sihatch)
as long as you can control the combustion, IMO you will be fine.
Just remember, all it takes is 1 thing to go wrong (misfire, bad tank of gas, mis adjusted timing, bad water pump, bad fuel pump/fuel injectors etc...) and BOOM
so just make sure EVERYTHING is in working order.
Old Mar 11, 2007 | 10:49 AM
alpha's Avatar
Default Re: Max bore for stock gsr sleeve? (black99x)
If you go 82mm on stock sleeves with boost you will be sending that block out for resleeving sooner than you expected
Honda Sport
Jan 31, 2006 06:13 PM
SpoolnByYou
Dec 19, 2005 02:28 PM
B18 CYA
Apr 7, 2004 03:43 PM
Beave0101
Jun 13, 2003 03:36 AM
itr1236
Mar 10, 2002 05:18 PM
