Ok when adjusting the timing on your distributor...
Old Mar 10, 2007 | 09:58 AM
HTn00b's Avatar
Default Ok when adjusting the timing on your distributor...
I accelerated the timing all it can because the motor sounded right, when the timing is too retarded the motor blogs when it is too accelerated it ??? How it you know where to time it?
Old Mar 10, 2007 | 10:07 AM
THC07's Avatar
Default Re: Ok when adjusting the timing on your distributor... (HTn00b)
put your damn dizzy back in the middle. what are you trying to accomplish?
pre-ignition???
at the most advance it 1 or 2 degrees. and you can check the timing with a light down at the crank pully.
Old Mar 10, 2007 | 10:17 AM
doood's Avatar
been there done that
Default Re: Ok when adjusting the timing on your distributor... (THC07)
it's best left at the stock setting. you need a timing light to correctly do it.
andyvaj
May 7, 2007 07:34 AM
miksew
Jun 7, 2006 08:03 AM
rice a roni
Aug 25, 2005 07:17 AM
johnbrooke86
Aug 23, 2004 04:49 PM
