how to install brake lines ----
Does anybody know how to replace the stock brake lines with upgraded steel ones? how hard is it, and what do you need to do?
very easy to do, make sure u get flare nut wrenches. Take out all the brake fluid to make things easier then unbolt the line to the caliper and then the other side to the hard lines.
how do you bleed brakes correctly?
I don't have the steel braided brake lines right now to answer the above request
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
Dude, search. There are like 5 how-tos on bleeding your brakes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 »</TD></TR><TR><TD CLASS="quote">Under the rules: if you say search, you're supposed to give a link or don't say search at all.
The rules also apply to you. He may be breaking the rules by saying "search, n00blet," but you are also breaking the rules by not searching in the first place.
</TD></TR></TABLE>The rules also apply to you. He may be breaking the rules by saying "search, n00blet," but you are also breaking the rules by not searching in the first place.
bleeding brakes 2 people one with wrench at farest brake first says push other guy steps on brake, guy with wrench loosens 8mm nipple thingy brake fluid pops out and guy with wrench tightens and says release, other guy releases brake. repeat until brake fluid comes out smooth, repeat for all lines also pump the brake once and a while thats it. you can but don't have to take off the wheels your choice. hope that helps if not hire that guy to teach you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gato5254 »</TD></TR><TR><TD CLASS="quote">bleeding brakes 2 people one with wrench at farest brake first says push other guy steps on brake, guy with wrench loosens 8mm nipple thingy brake fluid pops out and guy with wrench tightens and says release, other guy releases brake. repeat until brake fluid comes out smooth, repeat for all lines also pump the brake once and a while thats it. you can but don't have to take off the wheels your choice. hope that helps if not hire that guy to teach you</TD></TR></TABLE>
Or you could use a speed bleeder, if you have no friends.
Actually I wasn't breaking the rules.. That question wasn't my first post, it was "how to install brake lines". There wasn't anything when i searched... I thought then asking people now in the posting would produce faster and better results than searching again.
Thanks.
Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">
Or you could use a speed bleeder, if you have no friends.</TD></TR></TABLE>
ok i only make friends to help bleed brakes, explain how to use the speed bleeder. so i can kick the s**t out of my buddy. never used them thought about getting them but why spend the money. when i can buy beer. oopps better not beat up friends or no more free beer. they LOVE BEER
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 »</TD></TR><TR><TD CLASS="quote">Actually I wasn't breaking the rules.. That question wasn't my first post, it was "how to install brake lines". There wasn't anything when i searched... I thought then asking people now in the posting would produce faster and better results than searching again.
Thanks.</TD></TR></TABLE>
You must suck at searching...
» Search Results
Your search for brake lines returned 171 results.
Try harder, I swear people are getting lazier and lazier.
» Search Results
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">
» Search Results
LAZY people rule, you want to know why because they invent cool stuff like the remote control BUT YEAH SEARCH GUYS it's not hard. i hope the invent a way to stab people over the internet. i read that some where on here
» Search Results
</TD></TR></TABLE>LAZY people rule, you want to know why because they invent cool stuff like the remote control BUT YEAH SEARCH GUYS it's not hard. i hope the invent a way to stab people over the internet. i read that some where on here
you dont have to bleed if you change pads (if youre opening the bleeder to do this, youre taking about 3x as long as you should to do a brake job)
I dont like speed bleeders though - I use a vacuum pump
to "eric cartman" I do own a full set of craftsmen tools and do all my mods myself, just not this one. Just ordered a helms manual which should really help.
Check this out:
Check this out:
I just did this job last week, make sure you spray the brake line fittings with WD40 or something and let them sit for a minute, you can use a 10mm wrench, but flare wrenches are better for this no question. It is basically as easy as remove old line, attach new line (you may need pliers to get the line retention clips off), bleed brakes.
datssoled
10
Jan 9, 2007 07:51 PM
Milano97
Jan 14, 2003 11:36 AM
