Is it hard to install stainless steel brake lines?
Hey,
I did a search and found some info, but not on what I was looking for...I'm trying to replace my lines with stainless steel ones...are they hard to install? About how long does it take? And do you just replace a part of the brake line, or the whole thing from the master cylinder down to each wheel? And can you use them with stock wheel cylinders and stock calipers? Somebody told me I needed to have an upgraded brake system, but I'm not too sure on how valid that is...Thanks.
[Modified by Milano97, 3:58 PM 1/14/2003]
Re: Is it hard to install stainless steel brake lines? (Milano97)
The metal lines from the MC run to the wheel wells. Then a rubber hose connects to the metal lines and goes to the calipers. SS lines only replace the rubber lines. It should be simple enough to install them and you don't need upgraded/aftermarket brake setup to do so. Just get some quality brake fluid because you will have to bleed the brakes after installation. Also be careful with the brake fluid, it will damage your paint.
Re: Is it hard to install stainless steel brake lines? (kommon_sense)
It's an easy swap. Just bleed the system REALLY REALLY REALLY well before trying to take a corner @ 80mph.
Re: Is it hard to install stainless steel brake lines? (98CTRCoupe)
Pick up a 10mm flare nut wrench before you get to work. Will make things a lot easier.
found a few links that might help ya out...
http://www.ntpog.org/mods/fifth-brak...kelines1.shtml
http://www.bseries.net/html/garage/index.php
if i can do it you can do it....civic is my first car i worked on and i did brake swap...put on es bushings, and im getting ready to build up my first engine...beside you have these guys here and they are super smart...well some of them are. so if i can do it so can you just don't get to worried about messing up and go to it man. If you need help I might have some pictures of it for a 93 civic coupe if that would help.
DEF
DEF
onyx00
12-11-2001 08:28 AM
