WONDERING IF SOHC TURBO BUILD UP HELP
Old Mar 7, 2007 | 09:27 PM
shownuff26's Avatar
Default SOHC TURBO BUILD UP HELP/OPINIONS
IF ANYONE CAN HELP ME I WANT TO TURBO MY SINGLE CAM ENGINE IN MY 96 CIVIC DX BUT WOULD IT BE BETTER TO PUT THE EX HEAD ON BEFORE AND MAKE IT VTEC OR WOULD IT EVEN WORK AND IF SO WOULD I ONLY NEED THE HARNESS AND ECU + SMALL MISC. PARTS. THEN IM GOING TURBO AND HOW MUCH BOOST CAN I RUN ON STOCK INTERNALS ? SHOULD I UPGRADE TO RUN MORE BOOST CUZ I WANT AT LEAST 200 HP. TO THE WHEELS. CAN ANYONE POINT ME IN THE RIGHT DIRECTION THANX.
Modified by shownuff26 at 12:21 AM 3/9/2007
Old Mar 8, 2007 | 08:07 AM
devnull's Avatar
TURN OFF YOUR CAPSLOCK!
I want to help, but your post makes me think to much. Please rewrite your post and make it more readable.
Old Mar 8, 2007 | 11:20 PM
shownuff26's Avatar
Default Re: (devnull)
i can read it just fine . no biggy ill figure it out thanx anyways.
Old Mar 9, 2007 | 12:26 PM
cueballsi's Avatar
Default Re: SOHC TURBO BUILD UP HELP/OPINIONS (shownuff26)
u can make it on a non vtec motor, but it may be easier to achieve with the vtec head. I believe mini me sawps have higher compression... not 100% sure... but you want low compression for high boost applications. one of the first things you should change is your radiator, get a dual core, and if possible a aluminium one. also what kind of turbo do you want to do ... smog legal, or home made, or a nice custom set up.... let me know hit me up on IM
Old Mar 9, 2007 | 07:26 PM
shownuff26's Avatar
Default Re: SOHC TURBO BUILD UP HELP/OPINIONS (cueballsi)
Well im probably going to go with a small turbo maybe one out of a mitsu. gs-t or something along those lines ,im not sure the size of that turbo. they say a t-3 would be good cuz it spools really fast but im not sure whats best cuz ive never gone turbo before ive always done eather all motor or mass amounts of nitrous so im looking to do something different. my homie told me to go mini me with the older integra pistons but like u said , i think the comp. would be to high. ill probably go with a cross between a custom and home made kit for one im on a budget and either way i go here in cali its hard to smog most stock cars so it doesnt really matter to me , my unc,. will smog it for an 18 pack of bud- anyways.could i do the v-tech conv. and the turbo custom kit for about 2 g's or will it cost more? thanx for the help.
Old Mar 10, 2007 | 12:52 PM
menoSi's Avatar
with 2g's you could just about do the vitara setup and get 400hp. i did my setup with $500 and had my car running 13's. so sounds like youll have a way better build with that amount of money...
Old Mar 11, 2007 | 09:16 PM
shownuff26's Avatar
Default Re: SOHC TURBO BUILD UP HELP/OPINIONS (menoSi)
Vitara setup? sorry im not familiar with that but u say u did yours for 5 bills thats crazy cuz parts for turbo setup that ive seen are pretty pricy. thats about what im shooting for to run 13's nothing to extreme cuz its still my daily driver . thanx.
Old Mar 11, 2007 | 09:50 PM
cueballsi's Avatar
The viatar set ups is running pistons from a guy fjt he is on http://www.turbod16.com
http://www.turbod16.com/viewto...db41b
they are like $130 shipped. then a set of eagles are $300... so $430 is the total.... proble is that you have to check your bore first and make sure it is round.... cuz it is a 75mm piston which is the stock bore of the d16.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shownuff26 &raquo;</TD></TR><TR><TD CLASS="quote">Vitara setup? sorry im not familiar with that but u say u did yours for 5 bills thats crazy cuz parts for turbo setup that ive seen are pretty pricy. thats about what im shooting for to run 13's nothing to extreme cuz its still my daily driver . thanx. </TD></TR></TABLE>
Old Mar 18, 2007 | 12:04 AM
1wiperDude's Avatar
good luck w/ ur build... im lookin to go turbo w/ sohc... so im doin my reading too
Old Mar 18, 2007 | 01:55 PM
standbackimapro's Avatar
If i was doing a custom d series turbo, id use a 14B, honestly, id leave it how it is
How many miles on the motor? you can make 200hp when tuned
There are alot of companies that make full d series turbo kits
awaludinyuli
Feb 10, 2014 08:02 PM
altoid
18
Sep 25, 2002 04:58 AM
B-Series Sol
Jul 16, 2002 12:47 PM
DreamSpeed
Jun 26, 2001 04:41 AM
