VTEC Turbo or None VTEC
Old Jul 16, 2002 | 08:53 AM
B-Series Sol's Avatar
Default VTEC Turbo or None VTEC
What is better for Turbo Application?
SOHC DX motor (no vtec)
--or--
SOHC EX motor (vtec)
--or--
DX Block w/ EX head
I can get all the parts for relatively cheap... so basically im asking how to make the optimum SOHC Turbo Setup.. let me know, tell me what pistons i can use too. I heard that ZC pistons are good. Also, how much boost can this setup handle daily?
Old Jul 16, 2002 | 08:55 AM
SiRkid's Avatar
Default Re: VTEC Turbo or None VTEC (B-Series Sol)
ex
Old Jul 16, 2002 | 10:13 AM
Default Re: VTEC Turbo or None VTEC (SiRkid)
Really? I heard VTEC motors are usualy higher compression and have valve overlap which is poor for boost. Maybe I am totally wrong, but I was told by someone that no VTEC is optimal for Boost, but then again it seems like everyone running Boost here has an EX motor... hmm???
Old Jul 16, 2002 | 11:42 AM
M.A.R.C.'s Avatar
I would think the overlap part is true but i don't think it would be that big a difference when comparing sohc vtec vs sohc non vtec. Also as far as I know the compression ratios are the same between sohc vtec vs sohc non vtec.
Old Jul 16, 2002 | 11:46 AM
98DC2's Avatar
heard the same, but also heard that vtec helps spool whine up faster...
Old Jul 16, 2002 | 12:00 PM
CovertFI's Avatar
Default Re: VTEC Turbo or None VTEC (98lagen)
there was a discussion about this a couple of months ago. they said no matter what VTEC will always make more hp
Old Jul 16, 2002 | 12:45 PM
Default Re: VTEC Turbo or None VTEC (CovertFI)
so, should i take the SOHC-No-VTEC out of my EK... or just do the mini me swap... the plan is for a low 13 sec turbo.
Old Jul 16, 2002 | 12:47 PM
CovertFI's Avatar
vtec is always better
H(alo)oNdA 5thG
Mar 1, 2006 07:06 PM
ThrillaKilla
May 8, 2003 10:44 PM
h22accordturbo
Aug 19, 2002 09:41 AM
Threshld1
21
Aug 15, 2002 05:46 AM
hondanacura4life
May 19, 2002 07:58 PM
