External Wastegate? Where does the excess exhaust go?
Old Mar 7, 2007 | 08:34 PM
dezerte's Avatar
Default External Wastegate? Where does the excess exhaust go?
I know with an internal wastegate the excess exhaust gases that aren't needed to spin the turbine are just vented into the exhaust. But with an external wastegate where do the gases go? Are they just released into the engine bay?
Old Mar 7, 2007 | 08:57 PM
redboost10's Avatar
Default Re: External Wastegate? Where does the excess exhaust go? (dezerte)
it is released out the exit of the wastegate into a dumptube, which usually exits below the oil pan to keep the engine bay cleaner, or you can route it back in the downpipe
Old Mar 7, 2007 | 09:04 PM
DaveF's Avatar
Default Re: External Wastegate? Where does the excess exhaust go? (redboost10)
mine dumps right in the cabin, i have a pipe that comes out from the floor board and aims right toward the driver, it keeps me warm on cool nights
Old Mar 7, 2007 | 09:08 PM
redboost10's Avatar
Default Re: External Wastegate? Where does the excess exhaust go? (dturbocivic)
i heard that helps with breathing also, clears the lungs or something
Old Mar 7, 2007 | 09:13 PM
Tornadom's Avatar
The dumptube on my Integra runs to *looks for turbo setup... realizes he is NA*. Nevermind.
In all actuallity though, it isn't too hard to have the dump tube route back into the exhaust system. Some people leave it open, others tie it back into the system... your choice.
Old Mar 8, 2007 | 02:33 AM
riceball777's Avatar
Default Re: External Wastegate? Where does the excess exhaust go? (Tornadom)
open dump tubes generally make more power because they do not disrupt the flow of the exhaust by not being routed back into the exhuast and it technicallys makes your exhaust piping bigger. its also much louder. its like running an open downpipe when you hit full boost
Old Mar 8, 2007 | 06:57 AM
sp00led's Avatar
Default Re: External Wastegate? Where does the excess exhaust go? (riceball777)
That and with an open downpipe you can scare the **** out of inicent bystandards beside you when you go WOT.
Cloneufc
May 13, 2009 05:57 PM
turboteg90
Nov 25, 2007 04:43 PM
biggmike2
Jun 26, 2004 08:28 PM
boondockgtr
Nov 13, 2003 10:00 AM
Integra808
Apr 3, 2003 06:08 PM
