wierd idle !
Old Mar 7, 2007 | 05:13 PM
HCJDM1's Avatar
Default wierd idle !
hey guys ive been having a wierd problem lately ... everytime i apply the barkes my idle will drop .. same with when i turn on the lights.
i have a 94' Dx stock .
i just replaced the distributor and the timing has been set .
i was thinking it might be the alternator not charging properly ....
some help would be appreciated
ooo and does ABS come standard with a 94 dx ?
Old Mar 7, 2007 | 05:43 PM
HCJDM1's Avatar
Default Re: wierd idle ! (HCJDM1)
bump !
Old Mar 7, 2007 | 06:42 PM
92ehatch's Avatar
the IACV/EACV on the back of the intake manifold controls the idle from every aspect.
When the car has an extra load put on it (headlights, brake lights, ac, heater fan) it takes away a little power and the car tends to idle lower. to fix this the IACV allows more air past the throttle plate to bring it back up.
now that we are past that.
clean the thing out.
2, 12mm bolts hold it on to the back of the intake manifold
undo those bolts.
pull away the IACV, its gonna be black/nasty/carbonized/blah blah
take a handy dandy can of carb cleaner and spray that crap out
now its all white/silver/shiny/orbitz clean
go ahead and replace the gasket on the iacv, its figure 8 shaped, 4.97 from Honda, special order part.
put 2, 12mm bolts back on
warm car up, drive, test, be happy.
come back if that doesnt fix it
Old Mar 7, 2007 | 08:13 PM
HCJDM1's Avatar
Default Re: wierd idle ! (92ehatch)
ok ... i have pulled it befor .. it didnt look to bad ... so i just dusted it off nad put it back on .. i didnt know i can spray the crap out of it with carb cleaner ... (is coil cleaner ok ?)
and it never had a gasket ... ill just get one anyway .
so i can just get the cleaner and spray the whole thing up and down, in and out ?
Old Mar 7, 2007 | 08:16 PM
Projekt_2nr's Avatar
yeah use carb cleaner, but also check your tps sensor to see if it's bad
Old Mar 7, 2007 | 08:20 PM
HCJDM1's Avatar
Default Re: wierd idle ! (Projekt_2nr)
ok cool guys thanks for the help ..ill do it tomorrow morning
Old Mar 7, 2007 | 08:22 PM
no problem any time
Old Mar 7, 2007 | 11:48 PM
byronl's Avatar
i have this same problem too
Old Mar 8, 2007 | 06:22 AM
92ehatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HCJDM1 &raquo;</TD></TR><TR><TD CLASS="quote">ok ... i have pulled it befor .. it didnt look to bad ... so i just dusted it off nad put it back on .. i didnt know i can spray the crap out of it with carb cleaner ... (is coil cleaner ok ?)
so i can just get the cleaner and spray the whole thing up and down, in and out ? </TD></TR></TABLE>
if it never had a gasket...no figure 8 o ring then id say that is your problem
Old Mar 13, 2007 | 02:41 PM
HCJDM1's Avatar
well this is back from the dead ...i used carb cleaner ... i sprayed it cleaned it... its all orbitz clean ..i reconnect it and my car is idle realy low like abuot to shut off low... what could the problem be im almost possitve all the connections are good ...
need help please !
thanks
Old Mar 13, 2007 | 03:16 PM
HCJDM1's Avatar
bump!
BlackJacket
Dec 8, 2013 10:07 PM
1991civicb16
Jul 16, 2011 12:38 AM
madmortar
17
Jun 19, 2008 03:22 PM
ic89
Oct 17, 2006 08:09 PM
94SHOWLS
Feb 17, 2005 12:31 PM
