Hunting - ITR engine in a mini - free case of beer
Old Mar 7, 2007 | 10:57 AM
16vmini's Avatar
Default Hunting - ITR engine in a mini - free case of beer
A free case of bear to anyone that solves my problem , basically i will let a picture tell you what i have :
anyway its in and running now , but "hunts" , and i want to find out if the CEL light flashes , 2 problems :
1) i dont have a CEL light as its in a mini , so anyone know what pins on the ECU controll the light ?
2) i dont have a little grey connector to short out to make the CEL flash .. as i have cut it from the loom , again anyone know the pins on the ecu ?
its a P72 ecu ODB2 ? out of a UK ITR
thanks for any help
Matt
Old Mar 7, 2007 | 12:45 PM
Andrew Sutherland's Avatar
Is this what you're looking for?
http://technet.ff-squad.com/wiring.obd2a.htm
Keep in mind thats for obd2a, theres another one for obd2b on that site I think.
Old Mar 7, 2007 | 01:23 PM
totsie7944's Avatar
Default Re: Hunting - ITR engine in a mini - free case of beer (16vmini)
wow i can't believe you put that engine in that car.... where'd you get the motor from?
Old Mar 7, 2007 | 01:26 PM
RTW DC2R's Avatar
if its hunting it could be a simple as a vacuum leak, or possibly TPS or IACV issue.
BoBo Racing's Avatar
Default Re: Hunting - ITR engine in a mini - free case of beer (totsie7944)
hey r u located in miami florida i think ive seen ur car before?????
Old Mar 7, 2007 | 02:23 PM
16vmini's Avatar
cheers guys , i run http://www.16vminishop.co.uk , and this is my first honda conversion .. learning allot !!!
anyway i have figured out that A18---gry/red-------MIL ( ECU LIGHT ) is the light , not sure if its a -ve or +ve that comes out the ecu .. but will find out tommorow.
also i think mayne the two wires i need to short out are :
C7---red/wht-------SCS (service check connector)
C8---lt grn ---------K Line (scan tool) (TXD/RXD (data link connector))
but could be wrong on that
what should the LIM light do in normally operation ? come on for a few seconds when you turn the key and go out if all is well ?
Matt
Old Mar 8, 2007 | 10:41 AM
16vmini's Avatar
arrr . .ok no luck today making a light flash .. A18 was not grey/red on my setup ?
anyone ??
Matt
Old Mar 8, 2007 | 11:57 AM
Tippyman's Avatar
Default Re: Hunting - ITR engine in a mini - free case of beer (slamdunk)
Check you idle screw. Turn it in until it's tight.
Old Mar 8, 2007 | 12:26 PM
typer_696's Avatar
Default Re: Hunting - ITR engine in a mini - free case of beer (Tippyman)
there are quite a few mini around with that swap. I will see if I can get in touch with them.
Old Mar 8, 2007 | 01:13 PM
neo_'s Avatar
Are you sure its an ITR engine? A P72 ECU is a GSR ECU. Also, ITRs come stock with a red valve cover. Either way if it is an ITR engine, you are using the wrong ECU on it. A P73 ECU is for an ITR.
Old Mar 8, 2007 | 02:19 PM
Big Phat R's Avatar
Where's D?
Old Mar 8, 2007 | 02:25 PM
D's Avatar
D
Default Re: Hunting - ITR engine in a mini - free case of beer (Big Phat R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">Where's D?</TD></TR></TABLE>
Here, but this has nothing to do with it being in a mini.
And yeah... it may be a few more years before mine is road worthy.
Extended Front Clip FTL btw.
Old Mar 8, 2007 | 11:35 PM
16vmini's Avatar
sorry it is a p73 ecu . checked today
Matt
Old Mar 9, 2007 | 07:58 AM
ITRacer121's Avatar
why dont you just run an OBD1 chipped ecu or Hondata?
You will make more power and be able to see what codes you are pulling with the datalogging
Plus you shouldnt have to worry with emissions because the mini was pre OBD1. correct?
Old Mar 9, 2007 | 09:12 AM
JDMorgan's Avatar
Default Re: (ITRacer121)
aem ems would be great. simplify wiring.
jpar195
Apr 7, 2008 12:01 PM
RGoose18
Dec 17, 2005 02:54 PM
JoeCDN
Jul 29, 2004 08:50 PM
nek0
Jul 9, 2003 04:49 PM
turbofed EX
Aug 20, 2002 05:16 AM
