5 bar map sensor how do you its bad?
If you have boosted 36psi then what is the problem??? Sounds like the sensor is fine to me. It just does not data log reading above 26? If thats the case then it seems to me that your hondata would be bad not the sensor...
sensor was on intake<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekthis »</TD></TR><TR><TD CLASS="quote">these sensors dont take vibration well, and they doo go bad, not often but can
use a cusion clamp if your sensor went dead next time</TD></TR></TABLE>It was mounted in intake manifold<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke »</TD></TR><TR><TD CLASS="quote">If you have boosted 36psi then what is the problem??? Sounds like the sensor is fine to me. It just does not data log reading above 26? If thats the case then it seems to me that your hondata would be bad not the sensor...</TD></TR></TABLE>The higher boost # were when sensor was brand new .This motor isnt goning to see more than 30psi.So how do i test sensor?
sihatch19
May 28, 2008 09:56 AM
