Omni 4 bar
Old Jan 26, 2009 | 01:49 PM
stockb18c's Avatar
Default Omni 4 bar
i just purchased a omni 4 bar and was wonderin if you any of you guys are running them and does it read fine on the dataloging
Old Jan 26, 2009 | 06:54 PM
jdm knight's Avatar
Default Re: Omni 4 bar
if you can get the aem 5 bar map sensor . I went through 3 different omni power 4 bar sensors and they were all bad. I had to retune my car just because of the map sensor.
Old Jan 26, 2009 | 06:59 PM
locash's Avatar
What EMS were you using? I use those sensors all the time with no problems..
Old Jan 26, 2009 | 07:15 PM
willyboyK20's Avatar
I would think you would have to retune your car when you put a different map sensor on there.
I was thinking of buying one of these also.
Turbo-charged's Avatar
i had an issue with one. the car i was tuning made 700 horsepower at 25psi one pull and the next pull it made 720 horsepower at "12psi" lol
took the sensor off, put on another of the same sensor and everything was fine. i think they changed glues or something at a later date? its a different color at least.
since then, ive used 20-30 of them with no problems. cant beat how simple and clean the install is.
Old Jan 26, 2009 | 07:44 PM
stockb18c's Avatar
ya im goin to be using it for ectune...i just dont want it to read wrong on the computer when tuning
Old Jan 26, 2009 | 07:48 PM
black_EM1's Avatar
Community Builder
Community Influencer
I've used the same one on 2 setups now with no issues. It's a nifty little piece. You'll be fine.
Old Jan 26, 2009 | 08:21 PM
mtber's Avatar
You won't have a problem. We are an authorized eCtune dealer & it works perfectly.
We have sold tons of hondata/omni 4 bar map sensors without issues!
Old Jan 26, 2009 | 09:02 PM
LastGenEK's Avatar
I bought one from ^ and it works perfect for 7,000 miles now at 12psi
Old Jan 27, 2009 | 05:44 AM
twkdCD595's Avatar
I have one as well, works great so far and cant beat the direct plug n play replacement design.
Old Jan 27, 2009 | 12:42 PM
ghostofnyc's Avatar
no issues with mine
Old Jan 27, 2009 | 06:33 PM
stockb18c's Avatar
^ thanks guys
Old Jan 27, 2009 | 07:35 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
no issues with mine and no cutting wires.
Old Jan 27, 2009 | 09:46 PM
ghostofnyc's Avatar
Originally Posted by hybridcivicls-t
no cutting wires.
+1
Old Jan 28, 2009 | 03:28 AM
nonvtecallmotor's Avatar
I've ran one all year long. I've run as much as 35psi without a problem.
sihatch19
May 28, 2008 09:56 AM
vtekthis
Apr 10, 2005 06:00 AM
Hybrid
Jun 27, 2003 05:15 PM
89civic1.8T
Jul 4, 2002 03:47 PM
